HELP - I'm stumped
Old Mar 20, 2020 | 03:55 PM
rallsqh's Avatar
rallsqh
Default HELP - I'm stumped
First the bike specifics - It is a 2008 Dyna Fat Bob with a Vance and Hines exhaust, Big Sucker air cleaner and a FuelPak FP3. Other than that no other engine work has been done.
Second the problem - Took the bike to Daytona for Bike week, rolled it off the trailer and it started right up. Went to leave the campground and everything was fine. Pulled out on the road and gave it throttle and it almost died. Pulled back into the campground, checked codes and got the Throttle Position Sensor and MAP Sensor. Replaced both of those, didn't fix the problem. Tore into the tank and check the fuel filter, housing and lines - nothing wrong there. Unplugged the FP3, still no fix.
If I slowly roll on the throttle everything seems fine. Just won't go anywhere when I jump on it under load.
Any suggestions?
Old Mar 20, 2020 | 08:10 PM
barracudajoe's Avatar
barracudajoe
I think I see the problem. It started with "I rolled it off the trailer". The Harley gods are pissed at you now!
Some trailers are really bouncy, check that all electrical connection are good and tight. Blocked fuel screen?
Old Mar 20, 2020 | 08:26 PM
Max Headflow's Avatar
Max Headflow
Try holding up on the fuel line connector at the bottom of the tank. Wiggle the line a little.
Old Mar 22, 2020 | 05:35 PM
cvcRUISER's Avatar
cvcRUISER
6th Gear
Something plugging your quick release on the fuel tank?
Had you done any recent mods or repairs?
I once had a pinched wire for a connector that wasn't used for my Streetbob in the area of the TP sensor. Sometimes it would be good for months and then once in a while the bike would die under quick throttle opening and then fire back up without a problem.
Old Mar 22, 2020 | 05:43 PM
Tall Timber's Avatar
Tall Timber
On one of my bikes i've seen it lose the map. try re-loading it from the FP3
Doesnt you speedometer needle go back down towards zero when it loses power?
Old Mar 22, 2020 | 08:54 PM
Suede Blue Man's Avatar
Suede Blue Man
Reminds me of a problem someone had years ago, they finally found they had a "pin-hole" perforation in I think a hose in the fuel tank, some rubber part like that in the tank.
Good luck finding the culprit
Old Mar 23, 2020 | 08:23 PM
Dynaglide92's Avatar
Dynaglide92
Check battery terminals. I have an big inch fxr that loves to loosen the battery terminals. Will fire up and rev while in neutral but will sputter while In gear and go on and off
Old Mar 26, 2020 | 12:25 PM
rallsqh's Avatar
rallsqh
Thanks for all the suggestions. I disconnected the check valve from the tank, and it leaked fuel like it was an open fuel line, Someone told me that this could be an indication of a pin hole leak in the in tank fuel line, and that a leak like this can cause any number of error codes. I have order the new line for delivery this weekend. I hope this solves the problem. If not I will try resetting my map and then start tracing wire connections.
Old Mar 27, 2020 | 07:15 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Did some "jokester" disconnect the fuel line at the gas tank?
Old Mar 28, 2020 | 09:45 PM
rallsqh's Avatar
rallsqh
No - the fuel line was connected. Just ran like a faucet when I disconnected it.
UrbanElite
General Topics/Tech Tips
May 26, 2016 06:45 PM
jlgrebe
Jan 7, 2015 04:38 PM
HeatherC
May 1, 2014 10:27 AM
ThaGlyde
Nov 20, 2010 10:22 AM
evad5150
May 20, 2010 11:04 AM
