Speedometer and tach stopped working
work in accessory . It cycles can read miles then you turn it all the way on nothing . Going down the road if to turn it off speedometer does work. Turn signals don't cancel either , I'm thinking ignition switch is bad not sure
Anyone else have this problem?
Could be an ignition switch problem. Make sure you have power going to the speedo, I believe it's an orange/white wire. As for the turn signals not cancelling, take a look at the speed sensor in the trans... Sometimes metal will build up on the sensor and not transmit the proper signal to the Speedo..
