Need starter replacement help. Quick!
Old Jul 21, 2007 | 05:10 PM
ettev's Avatar
ettev
Default Need starter replacement help. Quick!
I'm trying to replace a starter on a 2003 Wide Glide. I have the battery and battery box off the bike and the 2 allen bolts that mount the starter are out. The battery cable connections are off the starter as well. Should this thing just slide out of the engine case from the right hand side? It's hung-up and it feels like whatever it's hung on is spring loaded. Do I need to pop the left side case cover off to remove the starter is it just bound up on the flywheel? Is pulling on the starter to free it or dislodge it a bad thing? How the hell does this come off the bike?
Old Jul 21, 2007 | 05:46 PM
kerberos's Avatar
kerberos
Default RE: Need starter replacement help. Quick!
Remove cover
Disconnect battery cable and solenoid wire
Remove both starter mounting bolts and washers
Remove starter from right side of motorcycle.
According to the 07 manual
wt
Old Jul 21, 2007 | 05:55 PM
DGlide04's Avatar
DGlide04
Weasleteats is right. You'll have to remove the Primary cover, in addition to what you've already done.
There is a shaft (jackshaft) inside the primary with a gear on it that is pushed outward when the start button is pushed and engages the main gear on the clutch hub to spin the motor. That is actually bolted from the inside of the Primary and there is no way to get it off w/o draining the primary and removing the cover.
Old Jul 21, 2007 | 05:56 PM
ettev's Avatar
ettev
wt,
Thanks. The bendix (at least thats what they're called on a car) is hung up in the main ring gear. Afraid to force for fear of messing up that main ring. Crap. What now?
Old Jul 21, 2007 | 06:02 PM
ettev's Avatar
ettev
ORIGINAL: DGlide04
DGlide04,
Thanks. After looking at the new starter for gear attachment to the starter shaft I figured the primary cover had to be pulled.
jakwi
Shovelhead
17
Dec 31, 2018 08:20 AM
CZshooter
Jun 29, 2016 08:45 PM
hdparadox
Apr 11, 2015 12:30 PM
timeout
Apr 12, 2010 10:10 PM
ettev
Aug 12, 2007 06:28 PM
