Right up there with "which engine oil" this is one of the most threaded threads of threads, it's easily one of the most multiple thriced tripled threads!
If you were to put all the threads on a piece of paper and put them in a hat, nine times out of ten you'd probably pick an unrelated thread but that's not the point, sooner or later you'd find something else about something totally unrelated....but that's not the point.
Put all the cams on a piece of paper, now tack them to a dart board, take three darts and see it you can hit the dart board.
Now just put the damn 48 in there and be happy with it and you won't be more happy with any of the others!
I'll look into that Yw7h.
I've done a bit of research and I think the 48h will probably be a good fit, but I'm just wondering about the differences between the 48h, the TW222 and maybe the Cyclerama 570-2, stock 96 incher, no compression added.
I've been through quite a few threads, and a lot of em seem to be either big bore 88s or 103 and bigger, and usually for a touring bike or a bagger. Not a whole lot of threads I've seen that are aby good pertaining to a stock 96 in a lighter softail or Dyna, but the 48s come up a lot, and I know they run pretty good on the heavier bikes. The other thing is that I'm running a shorter 2 into 1 than some of these cams seem to like, and it ain't coming off anytime soon. So that steered me more towards something similar to a 48h as well.
Just put a 48 in my 08 fxdc with a fuel moto map. Truth be told its not a huge difference in the first 3 gears. I got it to get rid of that stuck in the muck feeling when passing on the highways and interstates, it does that in spades 👍🏻
