Can anyone help me figure out whats going on with this bike,17 fxdl 5500mi like new really,motor starts stalling out of the blue,gets worse barely make it home running like ****.after this happens some weird electrical like no horn no front l blinker no headlight hi beam,what the hell has happened?anyone?
i agree battery could be it - it's a fuel injected bike, so when things go bad there. did you check voltage with bike running and it not running? other guess would be bad gas or old gas as well.
just did that,it seems good both posts tight..also after that happened there's been check engine light on..i also thought bad fuel so i siphoned it out the tank n put fresh fuel in and it's still stalling after engine gets warm,this bike has no fuses i dont think
"No fuses?"
Somebody eliminated the fuse block?
Does it have circuit breakers, then?
How old is the battery?
If it won't idle, it could be the stepper motor.
"No fuses?"
There’s only the main fuse, so he probably means if anything works, everything works. No individual fuses to check.
