I I believe the manual for my 2008 indicates that it's a measurement from the top of the fork to where the oil starts, not necessarily a specific volume of oil.
Yes....with the spring out and the fork compressed measured from the top of the fork down to the top of the oil...pretty easy...just grab some bottles of oil and go to town...careful tho...the tubes fill up faster than you think they will...
Those fork seals are notorious for leaks. If it's not hemorraging fluid, then it could be a small piece of dirt in the seal. You can use 35mm camera film to slip between the tube and seal to "scoop" out the offending debris. Check yootoob on how to do this. Pry up your dust seal, to reveal the oil seal.
30wt oil is too thick for your orifices. 10-12-15wt max. Remember, these are "American SAE" viscosity numbers.)
You're in Sweden, where ISO #'S reign supreme. You'll be looking for "32, 46 & 68"
32 = about 7wt
46 = about 10wt
68 = about 20wt
You can mix/blend any of these as they are compatible. To make a "custom" viscosity.
