Clutch issues
Old Jun 23, 2020 | 12:03 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by brakeless
You Tube vids on how to. I bet the ramp assy came loose.
That might be the problem: Ramp Assembly Installation
Old Jun 23, 2020 | 12:39 PM
WS6 Formula
Originally Posted by Merrick Wiles
I'm all for constructive criticism, I misspoke earlier, I have the manual in pdf form! I don’t physically have it. According to or how I understood it, the pushrod didn’t need to be adjusted, the YouTube videos I have watched said it’s not necessary. This is not my first Harley, it is however my first WG, it a 97. I will definitely follow your instructions and go from there. Much appreciated
Yup you're right, there's no need to adjust as it stays the same before and after a new cable.
Here's a couple of links that are helpful on seeing how things go together, also good to get part numbers and Google search images to see what you're dealing with, and / or for ordering parts online.
Originally Posted by WS6 Formula
I'm not a fan of "Get a manual" posts, if someone asks for help and the only responses are "Get a manual" you are going to end up with a dead forum. Especially the new members, think they will come back or go elsewhere?
Old Jun 23, 2020 | 03:30 PM
Merrick Wiles's Avatar
Merrick Wiles
5th Gear
i really appreciate the links! Super helpful. I have followed what the manual says, but nothing changed. I will reseat the ramp and ball assembly and see if that is the issue. Really appreciate you guys, as I am pretty new to clutch adjusting and what have you!
Old Jun 23, 2020 | 06:35 PM
Merrick Wiles
5th Gear
Default I want to buy you all steaks.
Got him and took the clutch cable out and the ramp, one of the ball bearings uprooted and moved to the other slots. I greased them out everything back together and she purring and running like a kitten!!!
thank you all again, I couldn’t have done it without you!!
Old Jun 23, 2020 | 07:00 PM
brakeless's Avatar
brakeless
Right on, glad that was the fix. I'll take mine medium rare!
Old Jun 25, 2020 | 04:48 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Next time you in the clutch cable side, you might want to install the Burly EZ Boy clutch device. $25 and a 40% reduction in lever effort, with the same "lock-up" as before. The friction zone will be wider too...
Old Jun 25, 2020 | 06:37 PM
Merrick Wiles
5th Gear
much appreciated. I will have to look into this!
Jsvwrestle
Jun 11, 2018 02:05 AM
rick775472
Jul 5, 2015 09:08 PM
Mfd6049
Apr 8, 2014 09:36 PM
rdondes
Oct 23, 2013 08:16 PM
jerryw618
Jun 17, 2011 05:32 PM
