Will Super Glide Cast Wheel Rotor Fit A Bob Spoke?
Old Jul 25, 2007 | 06:13 AM
jmpancoast's Avatar
jmpancoast
Default Will Super Glide Cast Wheel Rotor Fit A Bob Spoke?
I just bought a 19" spoke wheel froma Street Bob off another forum member. I am going to put this wheel on an 06 Super Glide to replace the OEM cast wheel. Will my rotor (looks like the one in the picture) fit the spoked wheel?
Thanks!
[IMG]local://upfiles/23085/8109F90D86924794B986FD83C15A36DA.jpg[/IMG]
Old Jul 25, 2007 | 06:37 AM
sleepneagle's Avatar
sleepneagle
Default RE: Will Super Glide Cast Wheel Rotor Fit A Bob Spoke?
HD rotors are not model specific.
Old Jul 25, 2007 | 06:44 AM
jmpancoast's Avatar
jmpancoast
Thanks!!!!!
Old Jul 25, 2007 | 07:16 AM
mud's Avatar
mud
ORIGINAL: jmpancoast
pancoast,
the rotor is not interchangable between the spoke wheel and cast wheel.
You'll need to pick up the correct piece. About 130 from Zanotti,
if I remember correctly.
The picture looks like the one you will need for the spoke wheel.
mud
Old Jul 25, 2007 | 05:51 PM
jmpancoast's Avatar
jmpancoast
Thanks Mud. Now that I have read your post and looked at the pic I embedded, it is not the same rotor as came on my FXDI.
Looks like the new rotor is going to cost more than the wheel.
ANY USE ROTORS FOR SPOKES OUT THERE?
Old Jul 25, 2007 | 06:04 PM
piniongear's Avatar
piniongear
Are all you guys sure of this? I put my rotor off a cast wheel right onto a laced hub. Five holes...same center to center dimension and same radius. No problem for me, it just bolted right on......pg
Old Jul 25, 2007 | 08:31 PM
mud's Avatar
mud
ORIGINAL: piniongear
No doubt about it pGear.
Your 03 wheel is completely different from the 06.
mud
Old Jul 25, 2007 | 09:47 PM
piniongear's Avatar
piniongear
Mud....
Boy, do I stand corrected! I did not know there was such a difference. Thanks.....pg
Old Jul 30, 2007 | 06:01 AM
jmpancoast's Avatar
jmpancoast
Hey Mud, or anyone else who can chime in;
This is a link to a rotor I found on eBay and purchased.
http://cgi.ebay.com/ebaymotors/ws/eB...m=120145540698
Mind taking a look at it and seeing if the specs sound like it will work for me on the Bob spoke front wheel?
Thanks again.
Old Jul 30, 2007 | 09:21 AM
piniongear's Avatar
piniongear
That part number is shown as the disc to use for the RH disc on a 2003 Dyna, both narrow and wide front end. I have a 2003 parts manual, so that is why it's listed for a 2003.
The '-00' suffix of the part number means it was first used on a 2000 model. It is most likely good to use on a 2007. I think it will work fine myself.....pg
