Shifter Pawl
Old Jul 6, 2020 | 08:01 PM
Casper's Avatar
Casper
Default Shifter Pawl
My 2006 Street Bob,s shifter is stripped. He shifter pawl needs replacing..anyone have this issue? If so what was the approximate cost?
thanks all
Old Jul 8, 2020 | 12:04 AM
WS6 Formula's Avatar
WS6 Formula
thanks all
If it's the one on the transmission (#15), looks like about $20.00.
https://partsfinder.onlinemicrofiche...TER%20ASSEMBLY
Installing the new rear trans shift lever
Originally Posted by Frozen Crome
I took every ones advice and did it my self. I did not have to split the primary at all. First I took the shift lever off and slid the shaft to the inside and used a pneumatic hack saw with a normal hacksaw blade and guided it with my finger and ripped right through the shaft and pulled it out. I did have to unplug the spark plug wires and move them out of the way. I then loosened the trans shifter arm and with a 90 degree screwdriver I was able to pry the splines open a little bit. I tipped the top of the shifter arm towards the engine and there was enough clearance to sneak it out. The new shaft was already was never compressed so I did not have to pry it at all I just put it down in there at an angel and it slid right on no problem and I did not have to force anything it went right together about an hour and a half.
t059736
Apr 25, 2018 02:43 PM
Crusher
Oct 4, 2011 02:50 PM
WarLizard
Feb 13, 2011 01:53 PM
JacktheBagger
Oct 2, 2008 09:21 PM
