High Beam lights do not work
Old Aug 8, 2020 | 02:34 PM
falikmike's Avatar
falikmike
Default High Beam lights do not work
I wonder why high beam lights do not work? WHen I press the switch it tries to switch the light to high beam but then it switches back to low beam lights....
i have LED light from amazon....
what to do here? Like it tries to switch and then when it sees nothing happens it switches automatically back to low beam.
this is also the only code from ECU I get
B2133 235 High beam output shorted low HEADLAMP DIAGNOSTICS
Old Aug 8, 2020 | 09:20 PM
nevil's Avatar
nevil
I'm no genius, but I think you might have a short or other problem with your headlight. Did you at least look at the wiring for the light?
Swap it with the stock headlight, see if that works.
Old Aug 8, 2020 | 09:21 PM
falikmike's Avatar
falikmike
i opened it up and swapped with stock, stock works then i sprayed some electric contact wd specialist spray inside the contacts and the high beam seems to work again
and i am surprised i get the code for that in ICU....
Old Aug 9, 2020 | 05:06 AM
vonh12's Avatar
vonh12
If the stock light works and your led's from amazon don't I'd suspect the light.
Old Aug 9, 2020 | 08:39 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted
Old Aug 9, 2020 | 11:15 AM
Gearhead88's Avatar
Gearhead88
Chinese bulb ............personally ...... I'm ****in done with Amazon and them flooding us with asian junk
Old Aug 9, 2020 | 01:56 PM
falikmike's Avatar
falikmike
but daymaker is expensive as ****, you are talking about 500 usd overpriced thing....at least harley should think about their customers a bit, cause the default stock light is rubbish....
Old Aug 9, 2020 | 06:05 PM
RANGER73's Avatar
RANGER73
All your bike needs is a headlight to pass DOT minimums. Why would they GIVE you something they can sell you?
Roadtwister
Jun 10, 2017 08:26 AM
bangladave
Electrical/Lighting/Alarm
Sep 21, 2013 09:03 PM
Matt0987
Jun 20, 2011 12:04 AM
myking
Mar 10, 2009 11:10 PM
Bryan TTM
Sep 26, 2006 01:00 AM
