tripple tree 3deg. rake??????????
Old Jul 27, 2007 | 10:48 AM
Ratbasturd's Avatar
Ratbasturd
Default tripple tree 3deg. rake??????????
Anyone added rake a Bob?
Thinkin of doin it but want to get a idea of how much the front end will lower.
Old Jul 27, 2007 | 11:52 AM
xbox's Avatar
xbox
Default RE: 3deg. rake??????????
I'm interested in this too....
I'd like to bring the front out more...
So Do you just buy a new set of Forks right ?
Would'nt trowing a set of Wide Glide forks bring it out 5-6 inches ?
Old Jul 27, 2007 | 12:29 PM
Ratbasturd's Avatar
Ratbasturd
Not the forks change the trees.
Old Jul 27, 2007 | 12:38 PM
glide05's Avatar
glide05
Most articles that I have read frown on adding rake to a dyna by changing to a raked set of triple trees.
If you are talking about adding rake by using a cup set - this seems acceptable and of course will lower the front a bit.
Try one of the online rake/trail calculators. If you have already lowered the rear - then you are probably OK from a trail standpoint, but you will certainly scrape sooner as you have reduced the ground clearance.
ORIGINAL: xbox
5 or 6 inches ??????????????????
if you just change the fork tubes from SG to WG, you will get the following:
1) more ground clearance
2) a bit slower stearing response
3) a slight increase in overall length.
4) a bike that leans over a bit more on the jiffy stand.
Old Jul 27, 2007 | 12:40 PM
glide05's Avatar
glide05
ORIGINAL: Ratbasturd
Storz Performance makes excellent products.
I have not read through the catalog in a while but l;ast time I did, they do not recommend raked trees on a dyna.
Old Jul 27, 2007 | 01:28 PM
06 lowrider's Avatar
06 lowrider
3 degree is safe and you gonna spend at least 500 on just trees
Old Jul 27, 2007 | 04:21 PM
WS6 Formula's Avatar
WS6 Formula
Default RE: tripple tree 3deg. rake??????????
Here's two photos,one withzero degree triple clamps, and two degree Wide Glide triple clamps installed on a Low Rider. The Low Rider also hasa 21" wheel that brings the axle height up about a 1/2". Three degree triple clamps will drop the front a little lower, and 1/2"lower with your original 19" wheel.[/align][/align][/align]
[/align]
Old Jul 27, 2007 | 09:55 PM
js1268's Avatar
js1268
hey formula, what year are those wide glide triple trees on that low rider?
Old Jul 27, 2007 | 10:03 PM
WS6 Formula
ORIGINAL: js1268
2006, part numbers and all other info you can find here: https://www.hdforums.com/m_814521/tm.htm
Old Jul 28, 2007 | 12:56 AM
fendrix's Avatar
fendrix
I think I read somewhere that for each degree of rake you lose .2 inches. I know that you don't want to go anymore than 3 degrees of rake in the tree on a stock frame. Bad news in the trail then.
