baffled by baffles
Old Jul 28, 2007 | 12:55 AM
low06's Avatar
low06
Default baffled by baffles
have been running vance and hines straight shot slip ons since february. yesterday i installed v & h's quiet baffles. they're not. i don't notice any real difference in sound. perhaps a slight bit less raspy. also, i thought the baffles, with more back pressure, would improve mid range performance. but i don't think there's a difference. the bike does seem to be running hotter. is that likely or is is my imagination?
also, i'm heading out for a 10 day trip and was thinking about carrying a can of fix a flat. does anyone know if that can work on a tubed tire?
thanks.
Old Jul 28, 2007 | 05:19 AM
Black Bart's Avatar
Black Bart
Default RE: baffled by baffles
Low06,
Did you also install a high flow A/C? If you did then then you created an even leaner condition than the bike bike originally began with. You need a SERT to do a remap or have a remap done to richen up the fuel mixture. This will help cool it down.
Bart
Old Jul 28, 2007 | 06:23 AM
b5mac's Avatar
b5mac
Fix a flat isn't recommended for tube tires. If you have a flat on a tube tire you really need to replace the tube. If you are a HOG member you can get road side assistance to get you somewhere you can get it replaced.
ohwell 2011
Nov 6, 2012 01:07 AM
2007ELECTRICGLIDE
Sep 1, 2010 12:37 PM
jimmyroadking
May 20, 2008 08:28 PM
low06
Dec 11, 2007 03:19 PM
HDNY1
May 15, 2007 09:52 AM
