Efi flooded full pump?
after a while of doing this I didn’t hear the fuel pump working turning on the kill switch and ignition and got the check engine light and now the bike will not start.
If it is a flooded fuel pump what could I do to fix this?
I was trying to get my fuelpak 3 to sync with my phone which is suddenly stopped working correctly sometimes it will sync but still not allow me to turn off auto tune and gets a error when trying to map a new map before shutting off auto tune.
bike is 2009 street bob
Once CSP hits about 20 counts or motor running, fuel pump runs all rhe time. There is a mechanical bleed to keep 62PSI.
Now hitting the starter and not holding it down long enough to clear both cylinders and getting both running so it fails to start as you get off button too fast will indeed tend to flood it on the next starter press. Mine always cranks longer if I do that . Purposely doing it a few times will require you to go into starting a FI flooded motor. (Hold throttle open slightly and crank).. see owners manual for complete for your system.
This applies to stock. Not a clue how your seat of the pants tuner works. If cylinders and plugs are wet with fuel, it's flooded. Gas engines fire a mixture of fuel and mostly air as a vapor.
