Best Dyna Years?
Old Oct 23, 2020 | 10:37 AM
ChopSticks's Avatar
ChopSticks
Default Best Dyna Years?
I'm in the market for a Dyna, I've had a Nightster and currently have a Fatboy Lo, and potentially going to be living in another country for part of the year so wanted to export one there to have as transportation. I personally preferred HD's black out (non chrome) models, but are there any years I should necessarily worry about in regards to Dyna? For instance, I know the earlier softail models had some cam chain issues, and after a certain year sportsters went to canbus (not exactly an issue, but just something to be aware of, an actual issue would probably be Nightster ECM is fender mounted which other models aren't, which leaves a huge hole there if you decide to relocate).
So what should I be looking for? filtering out? a must?
Old Oct 23, 2020 | 11:04 AM
Reindeer's Avatar
Reindeer
'05 and older have the problematic spring tensioners on the timing chains. Not an unsolvable problem, but you need to be aware of them.
'06 models have significant changes from the older bikes. They have a few unique and well know issues. Again, not unsolvable, but may need to be addressed if the previous owner hasn't already
'07+ are generally considered fairly reliable
Old Oct 23, 2020 | 11:06 AM
Blue Bob's Avatar
Blue Bob
I believe in 2014 HD started using their SE upgraded compensator.
2014 would be the last of the factory upgrades / iteration of the TC.
Old Oct 26, 2020 | 10:42 AM
Joe12RK's Avatar
Joe12RK
98 and earlier would be the EVO motor, the most reliable and trouble free that Harley ever made.
Old Oct 26, 2020 | 12:08 PM
Bob_fxdb's Avatar
Bob_fxdb
Yes, them evo’s<3 watch out when they stop leaking, that’s when your engine dry
Old Oct 26, 2020 | 12:21 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Don't mix up the Evo's with the Shovels. They were not that problematic as oil leakers...
Old Oct 26, 2020 | 05:18 PM
TroubleHead Fred's Avatar
TroubleHead Fred
Neither my Evo's or my shovel leak oil, FWIW.
Old Oct 26, 2020 | 05:36 PM
razorbacksrule's Avatar
razorbacksrule
Default Compensator
The 07-2010 had problems with compensators i know Ive had 3 that did with low miles. Something you need to look for when you buy one.
Old Oct 26, 2020 | 06:36 PM
98hotrodfatboy
For a couple years now I've been very interested in the 2014 Dyna line with the 103's... I would really love to hear about them as well They must go like a banshee for a stock bike. They should also have the upgraded compensator.. I've seen them now for under 10 close to 9 on the market with low miles..
Old Oct 27, 2020 | 11:55 AM
Joe12RK's Avatar
Joe12RK
Neither do mine.
Harley got it right with the Evos, as long as you let them warm up before beating on them.
