Ape adding help
Old Nov 20, 2020 | 08:39 PM
lewistg's Avatar
lewistg
Default Ape adding help
My son has dropped off his 2003 wideglide. We are going to be putting some 14 in apes on. Question is, where are the handlebar wiring plugs at to remove and add the extended wires?
Old Nov 20, 2020 | 09:07 PM
brakeless's Avatar
brakeless
Usually under the tank. Hot tip for when (if) you run wires through the bars, drop a string in the end of the bar and blow compressed air into it. The string will pop out the hole at the bottom. Then tape your wires to it and pull them up.
Old Nov 20, 2020 | 09:14 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Look in your Factory Service manual, it's in there.
Old Nov 23, 2020 | 02:56 PM
redhog99's Avatar
redhog99
Default ape adding help
I just did this to my 1999 FXDS convertible. The main harness is stuffed inside the frame channel. In order to get it our you must remove the access cover between the rear tire and the bottom of the fender. Cut the cable tie holding the excess wiring loom and you can work the harness out from the frame rail at the front of the bike.
Old Nov 23, 2020 | 03:42 PM
snake_eyes's Avatar
snake_eyes
Don't frick around with re-pinning or cutting and soldering, do it right and get a wiring extension from these guys https://namzcustomcycleproducts.com/...ring-products/it's a no brainer.
srhen
Apr 21, 2016 05:15 AM
JHC210
2014-2024 Touring Models
13
Mar 6, 2016 06:35 AM
USMC_Vet
Apr 19, 2014 12:39 PM
CVO-RK
Feb 26, 2013 01:28 AM
low_wgn
Apr 25, 2011 06:42 PM
