How high riser to handle bar
Old Jan 15, 2021 | 02:31 AM
rogersachs's Avatar
rogersachs
Default How high riser to handle bar
I would like to raise my handle bars on my 2013 street bob . Presently they are mini aps 10 in. Can I add two inches via a 3 inch riser and not need to re cable or interfere with my fall away.
Right now I have the oem one inch riser.
Thank You,
Roger
Old Jan 15, 2021 | 04:21 PM
CanadianDyna's Avatar
CanadianDyna
Thank You,
Roger
Im not entirely sure of the stock height on the street bob but I changed to 12" mini apes and 1" risers on my fxdl using the stock cables. Mine had the gross stock angled risers and bars that rose a few inches ontop of that originally
Old Jan 15, 2021 | 05:27 PM
B1Java's Avatar
B1Java
That's good to know. I also have a FXDL (2016) and look forward to getting rid of that riser/handlebar/headlight contraption. I've heard 10" LD San Diego bars will work with the stock cables. Your setup gives me more confidence that it will.
Old Jan 16, 2021 | 06:58 AM
Garage Queen Rescue's Avatar
Garage Queen Rescue
Try taking the top clamp off the risers and lift your existing bars up a few inches. Take a good look at the clutch cable and brake line. Don’t forget to consider the extra bit of slack needed to turn lock to lock, may possibly need to pull a bit of extra wire out of the backbone.
Old Jan 16, 2021 | 04:51 PM
Wormjello's Avatar
Wormjello
The important thing to remember is that if you add 2 inches of height to your handlebars you’ll also have to get a 2 inch longer handlebar “Get Even” whip.
OrangeThunder
2018+ Softail Models
Oct 20, 2020 04:12 PM
smalls78
Feb 21, 2017 07:58 PM
FloridaDyna
Sep 13, 2015 09:43 AM
tfalcon
Mar 5, 2015 01:24 PM
MGN54
Aug 28, 2013 03:14 PM
