97 wideglide wont start
Old Aug 1, 2007 | 01:38 PM
jeffm's Avatar
jeffm
Stage III
Default 97 wideglide wont start
went to ride my glide to work today, turned the ignition on pushed the starter and turned over once then a "snap" sound and nothing no lights or anything. What should I look for first? or did the battery just die? the bike has been fine until now
Old Aug 1, 2007 | 01:39 PM
anubisss's Avatar
anubisss
Default RE: 97 wideglide wont start
Check your fuses.
Old Aug 1, 2007 | 04:48 PM
voyager1's Avatar
voyager1
' you could take the battery out. any dealer can test it.if all else fails .
Old Aug 1, 2007 | 05:34 PM
RJ98274's Avatar
RJ98274
Stage III
Check your ground from your starter to your frame -same thing happened to me tightened bolts and all good
Old Aug 2, 2007 | 07:41 AM
jeffm's Avatar
jeffm
Stage III
I worked on it last night. checked all fuses. all good, checked the circuit breaker had power their too 12.4 volts. so it looks like its the battery. I took some wire and hooked it up to a car battery(I don't have any jumper cables)and when I turn on the ignition switch I have power up at the gauges.The wire I had was to smal to try to start it.I think the battery had a internal short.The battery has like12.4 voltsI just dont know what that snap sound was
Old Aug 2, 2007 | 04:23 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Your issue sounds a little different than mine. I had lights, but bike would start.
I wound up (done this twice now) cleaning the batteryconnections/cablesand grounding connections/cable with rubbing alcoholand the bike started right up. Ensure you have the long, rectangle bolt in your connections where the screw is inserted, I was missing one.
caclark
General Topics/Tech Tips
Jun 25, 2014 11:39 AM
chiefaponte
Mar 13, 2013 02:23 AM
Krakanator
Aug 18, 2009 05:03 PM
chipoakes
Sep 18, 2008 05:31 PM
