Rear belt pulley
Old Apr 3, 2021 | 06:18 PM
Blake Rasnick's Avatar
Blake Rasnick
Stage III
Default Rear belt pulley
Hey guys, I did a bunch of engine upgrades last year and now I'm needing taller gearing. Stock rear pulley on my 99 wide glide is a 70 tooth,I think. I'm wanting to drop to a 68 tooth for taller gearing. I'm having trouble finding 68 tooth options. It's there another model that will interchange with my 99 fxdwg? Or a specific place you would recommend I look online? Thanks for any input.
Old Apr 3, 2021 | 06:36 PM
R_Einan's Avatar
R_Einan
It being a ‘99 with a 1-1/2” belt, there are few, if any, options available. You might find a pulley off another older bike that had fewer teeth, and have to retrofit the spacing for your application. The easier option may be to look at a different front pulley, but that will require pulling the primary.
Old Apr 3, 2021 | 06:39 PM
Blake Rasnick
Stage III
I was hoping to avoid changing the font pulley......but it's starting to look like my only option because I'm really having trouble finding a 68 tooth to fit my bike.
Old Apr 3, 2021 | 07:22 PM
R_Einan's Avatar
R_Einan
Unfortunately, it’s a 20 year old bike and a lot of the aftermarket parts that used to be available aren’t anymore.
Old Apr 4, 2021 | 12:47 PM
Blake Rasnick
Stage III
Sadly, this is true. But, I love the old girl, I'll figure something out.
Old Apr 4, 2021 | 09:05 PM
GREENOHAWK69's Avatar
GREENOHAWK69
I don't know if this can work, but I had someone mention a Sportster pulley being 68 tooth and had used them.
Old Apr 5, 2021 | 06:09 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I know the later model Sportsters are 68 tooth and I'm running one on my 2013 Dyna but the centering hole is 2.2" and belt width is only 1 1/8" where as the 99 down were still 2.0" center with a belt width of 1.5"... You can get a later model Sportster pulley but will need to change the belt as well so the cost is going to be up there.. I would just replace the front pulley to a 31.. Andrews makes them and are better than most.. And you can still use your OEM belt..
Old Apr 5, 2021 | 09:11 AM
GREENOHAWK69
Thought there might be more to it, thanks for the info.
deadhawg
Aug 20, 2023 07:07 PM
Yankee Dog
EVO
Sep 5, 2019 09:08 AM
rgr357
Oct 29, 2014 03:28 PM
rcroadrider
Jul 22, 2014 05:57 AM
Camaro67
Jul 7, 2012 11:35 AM
