Open turn signal not working
Old Apr 3, 2021 | 07:39 PM
Hoot Fowler's Avatar
Hoot Fowler
Stage IV
Default Open turn signal not working
Hi everyone. Had a problem with my 2014 Dyna Low Rider. Both left & right as well as the Tail light / Brake Light not working. Throwing codes of 2151, 2156 & 2161 which translates to all three circuits "Open". Front signals work just fine, but not the back. After running a zillion tests & even pulling the rear wiring harness out from inside the rear fender, swapping out turn signals, scouring the wiring diagrams, everything checked out individually along with resistance tests & continuity checks. Put a 9volt battery to each one & they all worked on the bench. What the Hell ??!!. then for ***** & giggles I powered everything back up again & alligator clipped a separate ground wire to the existing ground post on the rear circuit board t& touched it to the frame. "BINGO" !! Everything works. Why it needs a separate ground I don't know, but it works. Anyway, being new here I thought I'd offer my two cents to see if it would help anyone else.
Old Apr 3, 2021 | 07:54 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Good to know - thanks. May want to look at your wiring diagram and see if there is a separate ground somewhere in the circuit that may have gotten broken. Oh And Welcome to the Forum.
Old Apr 4, 2021 | 07:40 AM
John CC's Avatar
John CC
Yeah, it's not that it requires a separate ground, rather that it requires a ground and the one it's supposed to be using isn't working.
Bill Levens
EVO
26
Apr 20, 2022 05:39 AM
spb2002
Electrical/Lighting/Alarm
Nov 4, 2019 06:29 PM
DR.M3TAL
Nov 7, 2016 09:40 AM
SuperG96
Sep 22, 2016 07:01 AM
Darrin Palmer
Aug 5, 2012 02:30 PM
