Help!
Old May 11, 2021 | 03:41 PM
John CC's Avatar
John CC
Originally Posted by nevil
Here's a tip: You should always turn off the fuel petcock when you park the bike for the night.
Yeah, that. Float valves are man made and will eventually fail. Gravity, OTOH, has proven to be 100% reliable since the beginning of time.
Old May 11, 2021 | 10:31 PM
DYNADUDE777's Avatar
DYNADUDE777
3rd Gear
Originally Posted by MACDBF
Sorry to hear about the bike, but glad you are ok. Kind of hard to diagnose what 's going on fully without seeing the bike. Can you post up a few pics?
Fuel leaking out (plus all kinds of fluid under the bike) can be caused by a lot of things. Not sure if the throttle cable breaking would cause this much fuel to leak out. Let us know what you find out.
Mac
okay here’s a bunch of pics I just snapped
Old May 11, 2021 | 10:39 PM
DYNADUDE777
3rd Gear
That wet spot is all the gas that was sitting in my intake for the day
Old May 12, 2021 | 08:31 AM
John CC's Avatar
John CC
I would be concerned the crankcase is full of gas, but I am not sure how you could check that since it's (supposed to be) a dry sump...
Old May 12, 2021 | 09:57 AM
nevil's Avatar
nevil
Should be able to smell it, but I'd change the oil just to be sure.
From the 3rd pic, it looks like the battery has been leaking. Maybe it's from before but check it out.
Old May 14, 2021 | 08:22 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Be interesting to hear how the bottom got all scarred up. You dodged a bullet with just a scrape on the oil pan.
Old May 14, 2021 | 08:46 PM
TexasScooterTrash's Avatar
TexasScooterTrash
I'm lookin at the mouth of the carb . . . NASTY!!! Play it safe with a rebuild kit for the CV-40. While yer at it, convert it to an External Breather. The oil mist from the head breather is getting sucked back into the engine. Trust me, your piston domes and combustion chambers will look worse.
oldbie
Aug 28, 2020 08:37 PM
locknar
Shovelhead
11
Jun 25, 2019 07:52 AM
ambjon
Feb 29, 2016 10:52 AM
speedwaysteve
Feb 25, 2012 08:07 PM
