Longer Shocks on a Super Glide
Old Aug 3, 2007 | 02:59 PM
richdeerht's Avatar
richdeerht
Default Longer Shocks on a Super Glide
Has anybody done this? I'm tired of scraping pegs going around corners with my FXDCI. (Previous bike was a Sportster, and I never scraped pegs on it.) I've adjusted the stock shocks up all the way. It helped some, but I'd like a little more.
I 've seen some folks have put bagger air shocks on, which are nominally 1/2" longer than the stock Super Glide shocks. Has anybody tried Progressive Suspension 412-4002 (13") or 412-4003 (13.5")?
Old Aug 3, 2007 | 03:58 PM
glide05's Avatar
glide05
Default RE: Longer Shocks on a Super Glide
raising the rear without raising the front is generally frowned upon as it will have a negative afffect on trail and may produce undesired results.
you should be aware of this before proceeding.
Old Aug 3, 2007 | 09:43 PM
2002fxdp's Avatar
2002fxdp
try lookin to see if anyone has any FXDX parts since their shocks were 13.5 and i sure the front corresponds. plus its adj., front and rear
Old Aug 4, 2007 | 06:06 PM
woodreaux's Avatar
woodreaux
I talked to Progressive and they indicated that 12.5" shocksare the tallest allowable with stock pipes or slip ons that are similar to stock length.
Some of the VH pipes like Big Radius would allow you to go to a taller shock like 13".
In a discussion with Works shocks I was advised that raising the rear shocks alonemay make the bike steer faster.
I ride agressively and if you can live with shorter pipes you can go to a 13" or 13.5" shock like the FXDX/T. I would suggest increasing the fork springs with 13ish shock length. I use to have a FXDXT and traded it for a EG Classic for 2 up. I like the 07SB especially since I put the 103 kit in. I plan on going to 12.5" Progressive and change the fork springs and use a heavier oil.I'll just live with not riding as agressive.
Old Aug 4, 2007 | 08:19 PM
Critter174's Avatar
Critter174
I have a set of 12.5 progressive willing to sell at a good price want to change to the 11'
i only have about 3hours riding time on them going to order the 11' tonight . Let me know if you are interested i can get some close up pic's if you want. you can see them in my Sig too.
Old Aug 6, 2007 | 06:27 AM
richdeerht's Avatar
richdeerht
Yeah, it looks like the lower shock mount will hit the muffler if the shock is 1" longer than stock. Even 1/2" longer would be close.
Old Aug 6, 2007 | 07:04 AM
SPECIAL ED's Avatar
SPECIAL ED
True in theory, but in reality Harleys and cruisers in general are so low in the rear that raising the rear isn't going to do anything but increase ground clearance and maybe, quicken steering a tiny bit. I don't see how that could be considered an undesired result.
Old Aug 6, 2007 | 08:13 AM
glide05's Avatar
glide05
ORIGINAL: SPECIAL ED
As you mentioned - This will change the trail and generally make it more responsive at low speeds (quicken the steeing), and somewhat less stable at high speeds. To me the latter would be an undesired result, but maybe not to others.
Old Aug 6, 2007 | 09:58 AM
ClarkFXDC's Avatar
ClarkFXDC
ORIGINAL: richdeerht
This Dyna (FXDX) has 13.5" shocks, and stock exhaust.
Old Aug 6, 2007 | 10:03 AM
ClarkFXDC's Avatar
ClarkFXDC
Here's tdshepard's (a forum member)06 with 13.5" Ohlins shocks.
