Cam Timing
Old Jul 5, 2021 | 07:29 PM
John Phipps's Avatar
John Phipps
4th Gear
Default Cam Timing
Is it even possible to get the cam timing wrong if the dots are lined up? The cams are slotted to assist in lining up the dots. I've just changed out the cam tensioners on my 88 twin cam. Now there is significant power loss and hesitation through the gears. I'm wondering if the the secondary time is not alined to the primary timing. Any help is appreciated. Thanks
Old Jul 5, 2021 | 07:30 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!!
Old Jul 5, 2021 | 09:04 PM
Screamin beagle's Avatar
Screamin beagle
It's possible to be off one tooth on either chain. Are your sure you put the pushrods back in correctly? They are different lengths for exhaust and intake. If you are using adjustable are you sure you followed the procedure to set them? The easiest thing to do is start backtracking your work.
Old Jul 6, 2021 | 09:38 AM
John Phipps
4th Gear
I know the rods are correct. It's possible it may be ignition timing also. I'll start there then double check rods, rockers and cam chain. Thanks.
johnwesley
Engine Mechanical Topics
Feb 11, 2018 12:30 AM
94 ultra
2014-2024 Touring Models
Oct 23, 2016 08:44 PM
hoppynwv
Exhaust System Topics
Jun 24, 2010 09:13 AM
SEDELUXE
Jan 25, 2010 08:22 PM
ollscool
Ironhead
Jul 4, 2008 08:58 PM
