Ape height
Old Aug 14, 2021 | 07:56 AM
Fireface's Avatar
Fireface
6th Gear
Default Ape height
Hey quick question, I have a 2016 Street Bob what is the max height I can go with apes before I have to change my wiring?
Old Aug 14, 2021 | 11:05 AM
TownesVanZandt's Avatar
TownesVanZandt
Someone with a SB may chime in. Otherwise you can easily trace the wires down and pull them out of the frame neck and see. Only takes a minute, then you can stuff them back in.
Old Aug 16, 2021 | 02:14 PM
snake_eyes's Avatar
snake_eyes
Are you talking wiring or cables or both?
I have a '17 FXDB and IIRC the stock bars are "12. There was a lot of slack in my wiring, I am running 12" WestCoast MX T-Bars right now with no extension. Cables were a different story. I previously had "16 Apes with 3" risers and definitely had to get new brake, clutch, and throttle cables. I don't think you'd even get 2" taller on the stock cables.
Old Aug 16, 2021 | 03:00 PM
Pinelimbs's Avatar
Pinelimbs
Old Aug 16, 2021 | 08:53 PM
REW13's Avatar
REW13
Old Aug 16, 2021 | 09:00 PM
Fireface's Avatar
Fireface
6th Gear
So I have the stock apes with 2 in risers and I am looking to get 14in apes with 1.25 risers. I just want to see if I need to replace my cables and lines
Old Aug 19, 2021 | 04:49 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Males typically 5'5" - 5'9" with females being smaller than 5'5".
Old Aug 20, 2021 | 08:51 AM
REW13's Avatar
REW13
Not familiar with stock height?
So...
12in(stock)? Plus 2in rise =14 you should still have room in the cables
14in with 1 and a quarter inch riser= 15in and a quarter
You might be fine?
Easy way to check take off the top clamp and place something across the bottom clamp and look at the wire clearance
Old Aug 21, 2021 | 05:32 PM
StreetBobUnit's Avatar
StreetBobUnit
I did 14's and needed extended cables but there is plenty of wiring.
Old Aug 21, 2021 | 06:44 PM
E-clip's Avatar
E-clip
I have an ‘07 Super Glide that I put Street Bob bars on before I went to 16” apes. Going from the stock buckhorns to SB bars was about a +5 height change (6” bars to around 11”). My wires were stretched to the max. So you might be able to swing 14” or probably 12”. A lot also depends on the shape/width of the bars and pullback and if you go from external to internal wiring.
Nevsat13
Sep 20, 2013 05:59 PM
FlatBlack12Bobber
Aug 14, 2012 09:46 AM
Redbob 07
Jun 23, 2010 03:39 PM
X90
Dec 4, 2009 04:25 AM
jackyl
Nov 8, 2006 12:29 AM
