Wiring inside the handlebars on apes
Old Aug 10, 2012 | 05:11 PM
FlatBlack12Bobber's Avatar
FlatBlack12Bobber
Default Wiring inside the handlebars on apes
I just got a set of apes that are about to go on the bike next week. One question, why don't more of you with tall apes run your wiring internally?
Is it the handlebars don't have this as an option or is it something else?
Old Aug 10, 2012 | 05:16 PM
PigInaBlanket's Avatar
PigInaBlanket
Mine are ran internally. Not sure why anyone would not want to do it unless they just don't want to do the extra work.
Old Aug 10, 2012 | 05:21 PM
soft 02's Avatar
soft 02
Its more work. People are lazy/cheep. If it was easy everybody would do it.
Old Aug 11, 2012 | 10:37 AM
NSCoyote's Avatar
NSCoyote
did mine internally as well, still gotta clean up the wires where they feed back int othe backbone/frame but. any bar swap should have them done internally just makes the bike so much more cleaner looking,
Old Aug 14, 2012 | 06:58 AM
FlatBlack12Bobber
ok what about throttle and brake and clutch cables be run through?
I know sometimes you see this done on really nice show bikes...is it possible with you everyday handlebar swap?
Old Aug 14, 2012 | 07:41 AM
soft 02's Avatar
soft 02
All it takes is money. The stuff required to run brake lines and cables in the bars is high dollar stuff.
Old Aug 14, 2012 | 09:27 AM
FlatBlack12Bobber
Would I need anything more than a extended cable kit?
Old Aug 14, 2012 | 09:39 AM
Dew Me's Avatar
Dew Me
For throttle you have to buy an internal throttle kit. Excile Cycles I think makes one people talk about?
For brake cable you'll need the correct angle fitting at the beginning (mc) and you'll have to drill a hole as early as you can.
Clutch cable you will have to convert to a hydraulic clutch and then do the same as brake cable.
Like Soft said, All it takes is money. Internal throttle kit and going hydraulic on clutch are both pricey.
Old Aug 14, 2012 | 09:46 AM
EricInNCa's Avatar
EricInNCa
That's it...
Bring The Metal
Dec 29, 2013 10:06 AM
Brunster11
May 15, 2012 06:13 PM
Dannell53
Apr 13, 2010 12:22 AM
FYRDOC
Sep 3, 2008 02:16 PM
Unibomber
Apr 28, 2008 06:30 PM
