Down sizing rear pulley
Old Aug 7, 2007 | 01:32 PM
garyw's Avatar
garyw
6th Gear
Default Down sizing rear pulley
Has anyone put on a smaller pulley , I've got a 72 right now , how small could i go to drop cruizing rpm's 500 to 1000 rpm
Old Aug 9, 2007 | 12:55 AM
squeeech's Avatar
squeeech
Default RE: Down sizing rear pulley
G'day mate,
Our dyna models get the 68 tooth sprocket, ( International/ australian models), and ...acording to my manual the USA gets a 70 tooth. I don't have a tacko, but if your into high speed cruizing the 68 is great at about 70mph. When the speed drops to 55 - 60 mph the bike is lugging a bit in 6th gear. In fact all the ratios seem a little high, ( around town you can't quite use 4th unless you break the limit a little). So I intend to get the US type 70 tooth. I posted asking the US part number for the belt to see if it was still the same as for the 68 tooth, but alas, no-one replied ... I'm sure i saw a way (do a search), to calculate the RPM's a any given speed, sorry I can't help with that one. Just so you know, the axle was in the middle of the swing arm slot and I GUESSED that a 70 would still work with just enough adjustment to play with, but if you are going more than 2 teeth you may need a new (overpriced) belt, that was why I was trying to compare part numbers. If you have the part number for the stock USA belt, and send it to me; I'll get the number for the belt here in australia then you will know what you are after if you go to a 68 tooth sprocket. They fit it to meet noise regs here in Australia.
hope I've helped and not confused the issue.
Graham 06 FXD Oz land.
Old Aug 9, 2007 | 05:59 AM
mud's Avatar
mud
Here ya go Graham:
US
rear sprocket black70 tooth 40576-06
belt 133 tooth 40015-00
INT
rear sprocket black68 tooth 40535-06
belt 132 tooth 40594-06
mud
ORIGINAL: squeeech
G'day mate,
Old Aug 9, 2007 | 06:37 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
Good info guys. Are you also sure that the front pulley is the same for US and Int?
Old Aug 9, 2007 | 06:44 AM
Trotter's Avatar
Trotter
The Trans sprocket is 32 tooth,US and Int 40659-06
giacomo56
Jun 24, 2015 05:24 PM
rcroadrider
Jul 22, 2014 05:57 AM
huey408
Feb 10, 2014 06:17 PM
superstandardFL
Apr 3, 2013 02:26 PM
Camaro67
Jul 7, 2012 11:35 AM
