Clunking over bumps!
Old Sep 3, 2021 | 05:50 PM
CRISPY1's Avatar
CRISPY1
Default Clunking over bumps!
I have a 2008 wide glide. I have rebuilt the front forks, replaced the front and rear motor mounts but every time I hit a bump i'm getting a clunk. I have replaced all that stuff and i'm dumbfounded at the moment. Any ideas on what I can check or if you've had the same issues? Thanks!
Old Sep 3, 2021 | 05:54 PM
Suede Blue Man's Avatar
Suede Blue Man
Check your fuel tank, one or both of the bolts may be loose.
Old Sep 3, 2021 | 05:56 PM
CRISPY1's Avatar
CRISPY1
Front of the tank, under the seat or both?
Old Sep 3, 2021 | 06:03 PM
Suede Blue Man
You go out there to that bike and grab that tank with both hands and see if you can move it or wrench it around a bit while yelling at the top of your lungs "I'm mad as hell and I'm not going to take this anymore!"
Old Sep 3, 2021 | 06:08 PM
CRISPY1's Avatar
CRISPY1
🤣🤣🤣🤣🤣brother i've tried that with everything else and no luck.
Old Sep 3, 2021 | 08:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Check the steering head bearings nut and the rubber bumper on the bottom frame. If the bumper moved the jiffy stand could be clunking on the frame.
Old Sep 4, 2021 | 04:46 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
My money is on the tank bolts.
Old Sep 4, 2021 | 05:17 AM
IronAss's Avatar
IronAss
First thing I would check is the steering head bearing.
Old Sep 4, 2021 | 06:32 AM
shodown220's Avatar
shodown220
As others have said check those front tank bolts and tighten as needed. It's quick and easy, common and makes a bunch of noise. Had them loosen on my 14 and thought for sure a mount or something was broken somewhere.
crzoomb's Avatar
crzoomb
There was an issue with part number 8 in the attached photo. The stock one was to thin and caused a thunk in the front end over bumps, I had the same issue on my ‘07 WG.
