What's the best rear motor mount to pair with the Predator front mount
Old Sep 8, 2021 | 04:32 PM
John CC's Avatar
John CC
Originally Posted by Kraken
I run a stock Harley rear rubber mount with a Sputhe rear stabilizer. Also running a Predator front motor mount and have been for about ~22k miles.
Same here, but I haven't gotten to 22K miles yet.
Old Sep 8, 2021 | 04:37 PM
John CC's Avatar
John CC
Originally Posted by Super Glidester
Semantics...when the engine and trans are bolted together they are an "assembly" but nice try at being a smart ***. too bad I'm not a dumbass or it would have worked
I understand exactly what Kraken is saying, but I haven't a clue what this has to do with it. I guess I must be a dumbass...
Old Sep 8, 2021 | 05:14 PM
Reindeer's Avatar
Reindeer
I'm in this boat also. Currently running a Predator front, probably overdue for a rear one. My plan was to go stock mount with Sputhe or Alloy Art rear stabilizer, but the Big Bear one looks interesting.
Old Sep 8, 2021 | 06:13 PM
TOE_CUTTER's Avatar
TOE_CUTTER
Originally Posted by El Chiguete
I've been using the Predator front motor mount for a couple of years now and I think I need a rear mount that works better than the stock design because I've changed the rear mount a couple of times because it's hitting the case when I hit bumps/holes, I don't necessarely think that those rear mounts have gone bad but that they don't work that well together with the Predator. Here is my reasoning:
The stock Dyna motor mounts stretch back and forth to dampen the vibrations but the Predator only compresses (like what ALL the engine mounts of cars/bikes) so what is happenin is that the stock design compensates the front and rear position when the mounts strech and maybe that's why it doesn't hit until the mounts really go bad.
So the type of rear mount that would be a perfect complement to the Predator front mount is one that only compreses and not stretches. Are there any like that out there? I know that the Kinetics Structure mounts do have separate bushings for lateral and vertical dampening but don't know if combining it with the Predator the vertical bushings will get overworked or not.
Another option that I don't know if it would help or not could be to put a support in the rear to stop the trans from going further down when you hit a hole just like some products that do that for the front of the engine when doing wheelies, but I haven't seen one for the rear, maybe someone knows of one?
PS:
The rear mounts that I've been using lately are the Hard Drive ones that do seem to be made of a softer rubber and maybe that is causing them to stretch more that they should...
Judging by your post, you hit a lot of pot holes / rough terrain where you live. The OEM rear mount is one of the best combined with a Sputhe or True-Track. What I think you need is better rear shocks to absorb the rough terrain. If your shocks don't dampen the hits, your rear mount is going to be taking a beating. The softer compound of the Hard Drive is probably compounding the issue.
My .02
Dave
Old Sep 8, 2021 | 07:03 PM
El Chiguete's Avatar
El Chiguete
My .02
Dave
Better shocks is always a nice plus to have but I'm not the only one with this issue @Rt13MFer is having ussies with the Predator + regular rear mount.
The Big Bear looks nice but it's the most expensive one
Old Sep 9, 2021 | 05:18 AM
Rt13MFer's Avatar
Rt13MFer
Im running some sweet Bitubo shocks, nice soft ride and still have rear mount problems.
Old Sep 9, 2021 | 08:45 AM
El Chiguete
We are on the same boat
Old Sep 9, 2021 | 11:48 AM
Blue Bob's Avatar
Blue Bob
Yep the anger spews like vomit too often on this forum.
Old Sep 9, 2021 | 11:52 AM
Super Glidester's Avatar
Super Glidester
or, you could say the **** is so deep you need wings on your boots to stay above it...
Old Sep 9, 2021 | 04:32 PM
John CC's Avatar
John CC
Isn't the rear mount the swingarm bushings?
The defense rests.
