MFG stickers on downtube
Old Aug 8, 2007 | 03:09 PM
nycfxdl's Avatar
nycfxdl
Default MFG stickers on downtube
Been a lurker for some time. Question - are there any legal issues for removeing the MFG stickers on the righ side downtubes ? The VIN is clearly on the neck, so it should not be an issue - in NYC. Just want to clean up the look.
Any feed back or experience would be appreciated.
Old Aug 8, 2007 | 03:11 PM
voyager1's Avatar
voyager1
Default RE: MFG stickers on downtube
that vin needs to be on there.
Old Aug 8, 2007 | 03:53 PM
Bassman's Avatar
Bassman
I'm sure if you ask H-D they will tell you if you remove them, it will void your warranty
Old Aug 8, 2007 | 03:56 PM
UltraDuke's Avatar
UltraDuke
I think you can remove them. just soak the sticker in syn3 otherwise your warranty will be void.
Old Aug 8, 2007 | 04:07 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
Welcome from INDY...
I am gonna pull mine the rest of the way off, it is starting to peel off anyway
Old Aug 8, 2007 | 04:26 PM
Punty's Avatar
Punty
ORIGINAL: Bassman
[sm=icon_rofl.gif] I am sure thatsomewhere a some dealers ears are ringing
Old Aug 8, 2007 | 06:18 PM
Ganooch's Avatar
Ganooch
ORIGINAL: voyager1
I think that you are fine removing those. As the OP stated, the VIN is clearly stamped on the neck.
Old Aug 8, 2007 | 06:30 PM
lilrooster76's Avatar
lilrooster76
In order to remove that sticker you will need to order the special sticker removal toolmade exclusivly for HD byKent-Moore. Available at all fine Stealers for only 37.95 + tax. These are very useful and since EVERYONE needs one they are temporarily out of stock andto our British friends, no worry's mate the are available to you for only 79.95 + 35.95 shipping.
HDWG....Indy here as well
Old Aug 8, 2007 | 06:36 PM
Punty's Avatar
Punty
I am sure you could remove it, if not what would you do if you had your frame PC or repainted?
Old Aug 8, 2007 | 08:03 PM
57springer57's Avatar
57springer57
why remove them ?
