Error Code B2136 Help
Old Jan 13, 2022 | 11:40 AM
b_dunc's Avatar
b_dunc
Default Error Code B2136 Help
Hello everybody, yesterday I bought a 2013 Street Bob and when I got it home I noticed a red dot just to the right of the base of my speedometer needle. I’ve studied the cause of this nonstop sense I got it home. I was seeing a bunch of different answers as to a cause so I finally figured out how to do a diagnostics check and cleared out all of the stored codes and only one kept popping up so I’m assuming this code is what’s causing the red dot. The code is B2136 and that means low beam output open. My question is what does that actually mean? Also, what are the steps in order to fix it? Thanks in advance.
FYI - when I bought the bike the previous owner did have an aftermarket LED headlight installed so I’m sure that’s what’s causing the code to pop up.
Old Jan 13, 2022 | 01:27 PM
WS6 Formula's Avatar
WS6 Formula
B2136 DTC code after installing Phase 7 headlight?
https://www.hdforums.com/forum/ignit...headlight.html
B2136 Code After Installing LED Headlight
https://www.hdforums.com/forum/elect...headlight.html
Old Jan 13, 2022 | 01:37 PM
kel03's Avatar
kel03
You know what headlight he put in, maybe give the manufacturer a call, may need a load equalizer. Previous owner probably quite aware, have you called him?
Old Jan 13, 2022 | 01:56 PM
b_dunc's Avatar
b_dunc
Not sure of the headlight to be honest as I bought it from a dealer. A load equalizer? Can you elaborate on this? I’m gonna have to look into it though. From what I’ve read what could be causing the problem is the LEDs don’t draw as much power as the factory incandescent bulbs so that could be tricking the system into thinking my headlight is out.
Old Jan 13, 2022 | 02:44 PM
CoolBreeze3646's Avatar
CoolBreeze3646
If you bought it from a dealer, take it back and have them correct the issue, they should not be selling bikes with error codes.
Also read what WS6 Formula posted in response post #2.
ntg433
Milwaukee Eight (M8)
Jul 30, 2022 10:40 AM
spankdog
Apr 27, 2016 07:25 PM
hover
Apr 20, 2013 10:14 PM
SkinnyonFatboyLo
Dec 4, 2012 03:21 AM
sincityharley
Dec 23, 2010 09:28 PM
