Crank no start
Old Mar 30, 2022 | 05:11 AM
Fireface's Avatar
Fireface
6th Gear
Default Crank no start
Have a 2016 Street Bob that I tried starting for the first time since winter. Fully charged battery was low on fuel. Filled it up fired the bike up ran for 10 seconds then shut off. Tried to start it and it just kept cranking with out starting. Please help.
Old Mar 30, 2022 | 11:45 AM
nevil's Avatar
nevil
Having the bike sit all winter with a low fuel level is a recipe for condensation build up. Especially if there was no fuel stabilizer in it.
Take a look at the plugs and check for codes.
You could drain out the gas (and maybe any water in the tank). Fill with fresh gas and a fuel treatment like Seafoam.
Old Apr 1, 2022 | 02:19 AM
Fireface's Avatar
Fireface
6th Gear
So I replaced the plugs, changed the fuel, no codes and bike still wont start. Been cranking so much there is fuel coming out the pipes. Am I screwed?
Old Apr 1, 2022 | 05:39 AM
nevil's Avatar
nevil
It's OK to change the plugs, but my suggestion was to check the plugs- were they wet or dry?
Next, check for spark. Use an inline spark tester, you can't check it using the old way of grounding out a plug on the motor, both plugs need to be in place.
Old Apr 5, 2022 | 12:00 AM
greg3131's Avatar
greg3131
sounds like an electrical issue . Is the bike stock ? Or does it have a tuner on it ? If so , what brand of tuner ?
Your not screwed , my bike hasn’t started in a year . If I win the lottery or a ‘money tree ‘ starts growing in the back yard.
I will take it to the dealership 😎
Old Apr 5, 2022 | 05:20 AM
Fireface's Avatar
Fireface
6th Gear
my bike has a vance and hines tuner. I am not getting spark though from the coil so I bought one and will install it when it comes in Thursday
Old Apr 5, 2022 | 07:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Did you check to see if there was power going to the coil?
Did you check the connector at the coil?
Did you check the fuses?
Don`t just throw parts at it.
Old Apr 6, 2022 | 04:07 AM
Fireface's Avatar
Fireface
6th Gear
so I checked my fuses, and power going to the coil everything was good just no spark at the coil
jory434
Aug 1, 2023 04:12 PM
HDBri
Jul 22, 2014 08:01 PM
Monti
General Topics/Tech Tips
Jan 15, 2013 08:36 PM
RaySeales
Oct 30, 2011 12:57 PM
Coyote72
Jul 10, 2006 03:17 PM
