Another Front Brake Thread
Old Apr 25, 2022 | 12:11 PM
snake_eyes's Avatar
snake_eyes
Default Another Front Brake Thread
I'm out of ideas. Got the new right side brake setup on my FXDB, so brand-new master cylinder, brand new caliper and brand-new lines and I can't get any resistance on the lever. I bled it, bled it again and a third time. No air in the system that I can see. Tried the lever zip-tie trick and it helped a bit but still too much travel and not enough braking. Bled it again with the MityVac, no change. I have no leaks but mush at the lever and too much travel.
The only thing I thought might be the issue was air trapped in the distribution block, but I unmounted it and tipped it both ways to drive the air up and nothing. I also have SpeedBleeders on the bike now. Any help would be most appreciated.
Here's a pic of the block.
Old Apr 25, 2022 | 07:38 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Might wanna give Galfer USA a call.
Old Apr 25, 2022 | 08:12 PM
GearheadMike's Avatar
GearheadMike
You probably have a master for a single caliper, not a dual.
Old Apr 26, 2022 | 12:05 AM
eriksweden's Avatar
eriksweden
IMO there is best whidth a mc. that is small in bore, so one for single caliper is fine.
Old Apr 26, 2022 | 02:12 AM
Bob_fxdb's Avatar
Bob_fxdb
What’s your setup?
if it was me, I would delete the splitter(galfer) and run two lines from the master cylinder
Old Apr 26, 2022 | 05:29 AM
tngarren's Avatar
tngarren
Maybe pads to far from the rotors?
Old Apr 26, 2022 | 06:47 AM
NEWROADSTER's Avatar
NEWROADSTER
I have not used speed bleeders, but I have figured out on the normal bleeders when I have used the mighty vac, it would pull air past the threads on the bleeders when I cracked them and continually pull air back in the system. I was only able to start the bleeding process with the mighty vac and then finish bleeding them manually. That was especially true on the rear brake. When I manually bleed them I move the lever very slowly when the bleeder is open and tighten it back up before it bottoms out. It always is a slow process for me. I have also left the cap off the master cylinder over night to try to let the air rise to the top.
All that being said, it can be a bitch some times. I have tapped the calipers lightly with a rubber hammer, thumped on the brake lines etc to try to get the air bubbles out. You probably have done all of this but this seems to work for me.
Old Apr 26, 2022 | 07:43 AM
snake_eyes's Avatar
snake_eyes
I shot them an email, we'll see.
Old Apr 26, 2022 | 07:44 AM
snake_eyes's Avatar
snake_eyes
No, it's a brand new 11/16 master. And as @eriksweden pointed out, you can run duals off a 9/16 also.
Old Apr 26, 2022 | 08:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Bob_fxdb
What’s your setup?
There is no advantage to doing that, and it would add more brake hose where air could be trapped.
OP:
You might try using a syringe, and pump the fluid in from the bleeder end at the calipers.
