Lithium-Ion
Old May 31, 2022 | 08:05 AM
snake_eyes's Avatar
snake_eyes
The point of this thread was to get insight on a Li-ion battery, not opinions with no experience, or regurgitating what all the old guys have to say about new-fangled technology and not to get scolded about not tending my battery. The battery needs to be replaced and for a measly 100 bucks more I can get the latest technology. I don't care about the weight, but if the Li-ion can go much, much longer without any tending that's what I want. For the record I DO have a tender, I just don't use it enough 'cause it's a PITA.
Thanks to you guys that posted some helpful info, you know who you are.
Old May 31, 2022 | 11:54 AM
REW13's Avatar
REW13
After re reading the first thread my post was pointless......
But try the Lithium and post your pleasure or pian from it
Old May 31, 2022 | 12:18 PM
HD_noobie's Avatar
HD_noobie
Twin power lithium on my ultra, I've had it 3 years now and no problems
I don't use the charger until I park it for winter
Play my radio a lot in the garage, sometimes 30 -45 min and it never killed it.
Never cared about the weight until I dropped my bike.
Old May 31, 2022 | 10:27 PM
Highwaymans's Avatar
Highwaymans
Thread just popped up on another forum a couple weeks ago about his Lithium battery going up in flames on his bike.....
Sorry, Im no where near replacing any battery in my vehicles with anything else than an AGM....
Old Jun 1, 2022 | 08:03 AM
Dudepants's Avatar
Dudepants
Had a Anti-Gravity Li-Ion battery in my 04 hardtail sportster. Zero issues. I even left it off a tender over a MN winter and it still fired right up in the spring. I think you just need to make sure you buy a reputable brand, like anything else really.
Old Jun 1, 2022 | 10:41 AM
snake_eyes's Avatar
snake_eyes
More hearsay. What brand battery was it? Some bottom-of-the-barrel, cheap-*** POS from Amazon? How old was it? First-gen Li-ion? Was the owner a moron? Did it catch fire from overheating or overcharging? Was it properly installed and maintained? Did the bike itself have issues? Sorry, they just don't burst into flames for no reason. Did it have a BMS? First-gen Li-ion's didn't and that DID cause issues like fires but has been fully rectified from everything I've read like this https://www.motorcycle.com/products/...s-vs-realities for example.
Here are my takeaways as I get ready to order my Lithium-Ion from HD:
  • Don't buy cheap (goes for everything though, right?)
  • Don't buy a 1st gen battery or any battery that does not have a BMS. The BMS prevents overheating, overcharging, and completely discharge the battery
  • Install and maintain as directed, including using the correct charger
  • Lithium-ion will deliver over 13 volts till the BMS cuts it off before complete discharge. The voltage does not decrease with the available charge
  • Lithium-ion discharges at a rate of approximately 1%/45 days
  • Lithium-ion has a discharge/recharge cycle capacity 2-4 times greater than a lead-acid battery (more than making up for any difference in cost)
  • Lithium-ion batteries have far greater CCA than lead-acid
Everything that I've read from anyone not quoting "the guy down the street" has been overwhelmingly positive on current-gen, BMS-controlled Lithium-ion batteries for bikes.
Old Jun 1, 2022 | 01:25 PM
rgb66's Avatar
rgb66
Pretty much everything Yankee Dog said is true. And no, I haven't seen a fire. The only thing I can add to that from personal experience is they do not like the cold. When it is cold, they need to be "excited" to be able to give the full output. Running the halogen headlight for a while or several start attempts and then it will spin the motor. However, using the starter to wake them up is really hard on the starter.
I ended up replacing the lithiums in my two year round bikes with AGMs. I will say that I am still using the lithiums I pulled out of those bikes in my summer bikes and they show no ill symptoms. I guess I may have to wait for winter to see if they do the same thing (luckily they have kickstarters)
Old Jun 1, 2022 | 01:30 PM
snake_eyes's Avatar
snake_eyes
I just reread @Yankee Dog post and you're right, I should have given him credit earlier. Thanks!
Old Jun 1, 2022 | 03:47 PM
crzoomb's Avatar
crzoomb
I’ve had the same AGM battery for 7 years, it’s on a tender when n the bike, I also remove it and put a tender on it over the winter. Still chugging .
Old Jun 1, 2022 | 09:03 PM
shaggieshapiro's Avatar
shaggieshapiro
Sounds like you have the answer you need. stop asking for "advice" and buy it.
