THe bracket inside the front light broke.....It has like 4 bolts that bolt the housing to the frame of the motorbike....
the bracket broke and I cant find the spare part
I searched here but I cant find it https://partsfinder.onlinemicrofiche...R%20W/%20PEDAL
The part you red arrow on the pasteboard image can be found on the same partsfinder page for your bike. Look at HEADLIGHT ASSEMBLY. Part #30 (#69356-06A, $196.99) is THE Complete HEADLIGHT ASSEMBLY. Yer never gonna find a headlight on the brake section.
on mine, the bracket is not riveted on...there are 3 bolts so I can take the bracket out and probably ........... it back together with that heat torch
Must have come loose once already. Rivets are used because they expand in the hole so there is on way the two parts can move relative to each other. Bolts tell me someone has worked on it in the past.
it does not look like, it looks very professional......i will take some pics so you can see.....
i do not want to buy the whole housing....it costs 200 bucks....no way....
i want to torch that bracket together.....
