Hey how's everyone doing out there I'm Qwik, I just got a couple questions I got a 2005 Dyna Super Glide EFI I was riding two weeks ago now this happened to me doing about 80 miles an hour expressway the bike cut off then I was able to get started while still rolling w start button ,but then it cut off and had since ,it has power fuel pump goes on horn works lights work I get nothing from the start button and the only way I can actually start the motorcycle is with a jumper wire in start relay position and it'll start the bike and the bike immediately dies ,I've checked and doesn't seem to have security I got a key n no Fob ... I've replaced the battery two days ago w a throttle x says made in USA ,,put new relays in there checked all my fuses contact points cleaned everything clean the Earth grounds on the frames I'm stumped any help would be much appreciated.... Qwik
Your 2005 Superglide is a twin cam dyna. Might get more help in another part of the forum as this board is for FXRs which all have evo engines. Good luck
Question, I have a 2004 Dyna Super Glide. If this is not the section for a my twin cam then what part of the forum should I be in other than the section titled Dyna Models. I just want to make sure I am in the correct section for my bike. thanks. wow, these Rush slip-ons sound really mean.
Youre in the right section but you should probably start your own thread to ask your question.
I replied to this thread because the person I was replying to owned a 2005 Dyna Super glide and was told this is not for his bike. I have the same bike except it is an 04 Dyna Twin Cam 88CI. thanks for your help.
No worries, nice bike BTW. I had an 05 and an 02 Super Glide. Great bikes and so much fun to mod and ride.
Make sure to start a thread about your question, you'll get a lot of good knowledge from this bunch.
I have a 02 Super Glide and a 05 Dyna Low-Rider and this is my go-to section for info on my Dynas, so no worries. When you replaced the battery, did you put an overnight charge on the battery using a smart tender? Will the engine turn over when the start button is engaged? If not, remove the round cover on the starter Bendix. Turn the key and push the plunger in to engage the starter, if it starts, and stalls out then you need to diagnose the run issue. Good luck.
