Red light
Old Aug 24, 2022 | 08:31 PM
Vipers Harley's Avatar
Vipers Harley
Default Red light
What is the round red light just to the right of the speedo needle? 2012 fat bob I'm assuming a security light? However the bike supposedly does not have security but this light will light up and turn signals stop working till the light goes off.
it happens very intermittently.
not yet sure if it has a tsm or tssm? No fob though so again I assume it's a tsm?
I guessing TSM going bad?
Old Aug 24, 2022 | 10:13 PM
Jay Too's Avatar
Jay Too
Check your oil sending unit aka oil pressure switch. Make sure the wire isn't broken or disconnected
https://itstillruns.com/harley-david...-12179658.html
Old Aug 24, 2022 | 10:21 PM
2500hdon37s's Avatar
2500hdon37s
Check out your front brake lever… they’re well known for getting a little sticky with age, grime, and corrosion not allowing the lever to return to fully extended and press the switch that turns off the brake lights. Try bumping the front brake lever forward more or a light stab and quick release of the lever next time the light comes on. If that’s the case the light will turn off immediately.
the red light on the dash is a body control module error light I do believe. At least I’ve had the light come on a few times and the sticky front brake lever has always been the culprit. Another quick check to see if the lever might be the issue is to see if your lever is sticking while parked with the ignition on and see if the brake lights stay on when you gently release the lever.
Old Aug 24, 2022 | 11:03 PM
TownesVanZandt's Avatar
TownesVanZandt
My 2012 Fatbob owners manual calls it Electrical Systems lamp. Typically brake switch or a bulb out.
Old Aug 25, 2022 | 06:31 AM
RANGER73's Avatar
RANGER73
As a process of elimination.
The signals stop working when the light is on.
Left side, right side or both sides?
This would indicate a
Right or left side, Bad bulb or wire
Both sides, a bad/failing TSM
Old Aug 25, 2022 | 07:08 AM
NEWROADSTER's Avatar
NEWROADSTER
Mine was the rear brake light switch that stopped working intermittently.
Vipers Harley
Thank you too all who replied and does. Appreciate it
Old Aug 25, 2022 | 09:37 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
2012 Dyna Models have a Body Control Module (BCM) and no TSM or TSSM.
Does it throw up any error codes?
Old Aug 25, 2022 | 02:22 PM
Vipers Harley
yes several codes
P0562
B2121
B2173
B2272
B2255
U0100
Old Aug 25, 2022 | 02:26 PM
Vipers Harley
Thank you too all who replied and reply
