Rear master cylinder options
Old Aug 26, 2022 | 07:01 AM
Rapidfire1's Avatar
Rapidfire1
Default Rear master cylinder options
Are there any after market or replacement options that are an upgrade to stock on a 2017 fxdb? I have a freshly rebuilt tokico caliper, new pads and a Chopper Hauss rotor with good stainless steel brake lines. The master cylinder feel is terrible. I’m looking for options that are direct fit or can be made to fit with relative ease. I have access mill/ lathe/ plasma table/ etc. but would prefer not to modify my frame.
Old Aug 26, 2022 | 09:07 AM
pgrchaplain's Avatar
pgrchaplain
"Feel is Terrible"? Are the rear brake Spongy? Why was the Caliper rebuilt? Is the Correct Brake Fluid being used? Does the Bike have ABS? Have you considered Rebuilding the Master Cylinder?
Old Aug 26, 2022 | 09:35 AM
Hey Man's Avatar
Hey Man
Is the master cylinder the correct bore for that caliper?
Old Aug 26, 2022 | 11:59 AM
Rapidfire1's Avatar
Rapidfire1
The stroke of the master is inconsistent feeling and spongy. The caliper was rebuilt because it was a used caliper and I wanted to go through it to make sure there were no issues, fluid is correct, do not have ABS. I have considered rebuilding the Harley master but it’s been kinda shitty and weak since new. If there are no better options it will likely be my next step.
Old Aug 26, 2022 | 12:13 PM
Rapidfire1's Avatar
Rapidfire1
I’m not sure what the stock rear bore size is, the caliper is off a GSXR 750 and the stock front master from what I can tell is 5/8 but that’s pushing fluid to two calipers.
Old Jan 10, 2023 | 08:32 AM
fat bastard 68's Avatar
fat bastard 68
What did you end up doing?
Old Jan 10, 2023 | 08:42 AM
Rapidfire1's Avatar
Rapidfire1
I couldn’t find any viable options without fabbing a new mount and since I’m without a shop at the moment I decided to just live with it for now.
Old Jan 11, 2023 | 06:21 AM
FX WideGlide's Avatar
FX WideGlide
Sounds like a mismatch in the bores of the master cylinder and the caliper and mentioned above.
Old Jan 11, 2023 | 06:27 AM
Rapidfire1's Avatar
Rapidfire1
It’s possible but there shouldn’t be any fluid restriction and it is still performing better than the stock brake assembly.
SublimeMe
Jul 22, 2022 03:47 PM
buyarbi
Shovelhead
May 26, 2022 06:28 PM
JR-Boston
Jan 12, 2014 01:33 AM
d-streetglidr
Aug 8, 2013 06:22 AM
4merRacer
Dec 1, 2007 05:25 PM
