I want to install a tank lift on my '07 Wide Glide. From what I have read from the searches, the tank lift on a Wide Glide doesn't work. From what I have read, the Trees will hit the tank.
Is this true? If not, which lift do I need for a 2" lift.
The 2" lift will cause tank contact, but you can remedy that by filing the rear (seat side) tank bracket forward (toward the bars). A dremel, round file, or chainsaw file should do the trick. File it about 1/8" or a little more and then be sure and slide the tank as far toward the seat as you can before you tighten everything down and you should be good to go.
Be sure and post pics when you're done.
I've got Jakyl's also, had to pull back on the tank while I tightened the bolts, gives me about 1/16 clearance on each side. Close, but it's not hitting.
