No power at all 2013 fxdb
Old May 1, 2023 | 06:33 PM
capekdw20's Avatar
capekdw20
4th Gear
Default No power at all 2013 fxdb
Having an issue with my 2013 street bob. Bike has sat for about a month and had no issues when parked. Went to start it and nothing lights up. Checked the battery and even bought a new battery. Changed batteries in my key fob multiple time and still nothing. Checked fuses and changed ignition switch. I have voltage at all fuses and the ignition switch. Dash does not light up and no noise of anything powering up when I turn the ignition on and hit the run switch.
anyone have a similar problem? Thinking maybe the alarm system is messed up idk.
Old May 1, 2023 | 06:59 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I would start with the ignition switch....
Old May 1, 2023 | 07:01 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I 've got a couple of older Dynas with the basic HD electronic security systems. If my bikes aren't used for a month the bikes go to sleep. I have found by turning the ignition to on then off then back on, the bike "wakes" up and responds to my key fob inputs. My 2013 Road Glide doesn't do this due to the constant power demands while it's sitting still for a lengthy time. I'm in the snow belt that's why the bikes are laid up.
How old and what condition is the battery in?
Old May 2, 2023 | 09:20 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Is the kill switch in the on position?
Old May 2, 2023 | 01:39 PM
seniorsuperglideE8
Just read where you have replaced the battery, somebody suggested the ignition switch, have you cycled the ignition switch a few times, could have dirty/corroded contacts under the switch.
Comp
Mar 25, 2023 12:36 PM
PKeithkelly
Mar 1, 2023 07:53 AM
Luckyeight
Electrical/Lighting/Alarm
Mar 4, 2019 03:10 PM
shelbyjay
Apr 2, 2015 02:47 PM
fireman031967
Oct 9, 2014 02:29 PM
