No power in ignition position, OK in accessory position
Old Feb 22, 2023 | 05:44 PM
PKeithkelly's Avatar
PKeithkelly
Stage III
Default No power in ignition position, OK in accessory position
2007 Fat Boy. Problem started 2 days ago. Went to start the bike, turned switch to Ignition position - nothing. No horn, no lights, no console lights, no neutral light, and nothing at starter button.
Checked battery cables - nice and snug
Checked all fuses - all good
Checked battery - 12.88 V (fairly new battery)
Swapped battery in key fob
(Yes, gearing in Neutral position)
Accessory position was bringing up time/odometer, etc, which i was able to toggle through, but switching to Ignition position brought nothing but darkness.
After a few minutes of trying and head scratching it came to life as normal and i rode away, confused but ...
The bike cut out on me and left me on the side of the road about 20 minutes later. Same thing, and after a few minutes the power returned and i made it home.
But same issue in my driveway today.
Thoughts on what i should check?
Appreciate any help
Keith
Old Feb 22, 2023 | 07:46 PM
702's Avatar
702
Sounds like a faulty relay to me.
Old Feb 22, 2023 | 08:26 PM
chopper_man's Avatar
chopper_man
bad ignition switch or loose wire on it.
Old Feb 22, 2023 | 08:34 PM
hattitude's Avatar
hattitude
One possibility is that the main ignition switch has dirty, corroded, and/or pitted contacts in the "On" position.
There are reports that on older Twin Cams with that center console ignition switch, the contacts are causing electrical glitches like yours.
I had a similar thing happen on my 2003 Heritage. I disassembled my ignition switch and found the main contact for the "on" position corroded and a little pitted. I cleaned up the contacts really well, and reassembled the switch with new grease. It's been several years since I experienced that glitch and it hasn't happened since the switch clean up.
Some people just buy a new switch, because there is no "procedure" for disassembling and cleaning of the switch. I took a digital picture at each step of disassembly in case I forgot how it fit back together, I would have a pic to refer to. It all went well, and was easier than I expected...
Here is a picture collage of the various stages of my switch cleaning, just to give you an idea of what's involved should you want to check it out...
Old Feb 22, 2023 | 08:48 PM
PKeithkelly
Stage III
thanks for the very detailed response. I'll pick up a new ignition relay at my local NAPA tomorrow ($8.00, so low risk experiment), and will check the switch too.
But just started snowing (in the mountains) so my experiments might have to wait a few days.
Thanks again
Old Feb 23, 2023 | 08:45 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
The switch assy is super easy to disassemble and clean and most can probably use a good cleaning and refresh.
Old Feb 23, 2023 | 08:50 AM
wmprof's Avatar
wmprof
2001 Heritage had same issue. Cleaned switch contacts and applied dielectric grease. Issue never returned.
Old Feb 24, 2023 | 05:58 PM
PKeithkelly
Stage III
Default problem solved
Thanks for the comments / responses/ advice/ pics about the switch.
The center of the three male spade terminals on the switch was really dirty. Gave it a cleaning and light pass with sandpaper, and presto .... back in action. But i took the switch off and took it apart to inspect/clean it too.
All back together and good now.
If only it would stop snowing!
Keith
Old Feb 24, 2023 | 08:15 PM
xltjim's Avatar
xltjim
Looks like you got it done. I had same issue with mine on 2006 heritage.
I agree on the snow comment.
Old Feb 28, 2023 | 02:36 PM
doreilly's Avatar
doreilly
Had the same problem on my 01 Heritage, glad to hear you found the fix
