mini mapes on superglide
Just a word of caution, was told by a tech at the dealer about a tech tip concerning using a popsickle stick or whatever you have for disassembly of the throttle grip. Before you take it apart pull on the brake lever and jam a popsickle stick in the opening so the lever will not close. Something about if you don't it could brake the nipple off in the brake switch when the brake is applied the first time after reassembly. I didn't do it but I had no problems. Not covered under warranty if you have still. I went to get the ecm recal done and told the tech about the bar change and he said, "Rear brake light doesn't work with front brake lever huh.". I said, "Hell I don't know, have to go check.". Here are the part #s and a quote from Zannotti's:
$41.76 Stock Street Bob bars 56079-93
$49.52 Bob front brake line 42728-06
$25.31 Bob clutch cable 38789-06A
$14.12 Bob throttle cable 56355-96A
$14.12 Bob idle cable 56356-96A
$16.73 Shipping
$161.56 Total
There is enough wiring tucked up in the frame to pull out but you may have to take that plastic cover off the bottom side to turn a plug around. I did pull the right blinker harness apart but just plugged it back in again. Good luck.
the bob is I love the mini apes very comfortable on a long ride.
I think the would look great on a super glide.
Should be an easy install just alittle time consuming.
good luck.
Thanks for the parts list and the advice on Zannotti's.
