Dyna Wide Glide Steering Head Bearing
Old Aug 15, 2023 | 11:11 AM
2500hdon37s's Avatar
2500hdon37s
Motor mounts are prone to failure on dynas, but yearly replacement is absolute nonsense along with flat spotting neck/ head bearings from sitting.
When your motor mount does go bad, or you want to improve it add an aftermarket motor mount like a vibratechnics predator mount and not have to worry about it.
Old Aug 15, 2023 | 04:43 PM
Bullshark001's Avatar
Bullshark001
Stage III
Default Vibration
Thank you so much to everyone for the comments, it’s saved me a heap of coin, much appreciated.
Now I might be being paranoid or cynical here, but I feel what I feel. So when I rode away from the mechanics shop there was a slight vibration in the handlebars that definitely wasn’t there when I rode it there. So is there a way I can check this out myself? I do have a friend that has a motorcycle jack to lift the bike up.
Old Aug 15, 2023 | 05:16 PM
hattitude's Avatar
hattitude
This may help you out with checking the mounts...
https://www.hdforums.com/forum/dyna-...vibration.html
Old Aug 16, 2023 | 09:38 AM
Two Lane Tramp's Avatar
Two Lane Tramp
The book Zen and the Art Of Motorcycle Maintenance by R. Pirsig describes enthusiasts as either Classics or Romantics. The Classic is constantly obsessing about every noise and vibration. Forever working on problems that are usually non- existent. The Romantic on the other hand ignores obvious issues and runs it till it breaks. Don't be either! Find that middle ground of sanity. My guess is you let that BOZO get in your head about nonsense.Half the fun of Harley ownership is learning about these great machines. There is a ton of information on these forums and even more on You Tube. You chose a great bike. The Wide Glide has always been one of my favorites. Enjoy.
Old Aug 18, 2023 | 05:39 AM
VTTIMWHITE's Avatar
VTTIMWHITE
Just "No" to the head bearing change. That's ridiculous.
There "might" be validity in upgrading the motor mounts, but yearly? Nope. This sounds like the kind of mechanic that will swap out your summer air for winter air in the tires. For a small fee. Find a new mechanic.
Old Aug 19, 2023 | 05:54 PM
benscratchin's Avatar
benscratchin
Question WideGlide vibrations:
Looking at my 2000 model Dyna FXDWG Owners Manual, it states "check" Front Fork Bearing adjustment at the 5000 mile service interval (what CHECK means it does not say).
At 10,000 miles the Owners manual states "Lubricate and Adjust Steering Head Bearings".
Then again at 15,000 miles it states "Check front fork bearing adjustment".
At 20,000 miles it again states "Lubricant and Adjust steering head bearings".
Looking at my 2000 model Dyna FXDWG Service Manual it states Bearing Adjustment (Fall-away) then describes the procedure. It's pretty simple. YouTube videos show the Fall-away check.
If you jack the front wheel up off the ground, then slowly turn the handlebars left to right and feel no roughness, your bearings are probably okay.
I bought my 2000 model Dyna Wideglide two years ago with 22,000 miles on it. When I got it home, I performed the 25,000 mile service interval in order to bring maintenance up to date for my own peace of mind, including removal, inspection, lubrication, and adjustment of the steering head bearings. At 22,000 miles the bearings looked fine.
The Dyna front engine mount goes bad first. Check the tightness of the bolts, it's pretty easy to do so. At idle does the engine vibrate excessively? A bad front motor mount will show signs of "sagging".
Check the tightness of the Handlebar bolts and riser, and the handlebar controls and levers
Youtube is a ggod source for Harley-Davidson maintenance. Your motorcycle "Owners Manual" and "Official Service Manual " is even better.
All Harley's have some vibration at the handlebars. Ride it and enjoy it...
mickier
Jun 28, 2022 10:54 AM
twowheelin
EVO
Oct 25, 2021 07:29 PM
General Hangover
Jun 29, 2019 10:40 PM
AussieDog
2014-2024 Touring Models
Sep 30, 2018 08:45 AM
hardheaded
Nov 5, 2013 08:31 AM
