Dyna Wide Glide Steering Head Bearing
Old Aug 14, 2023 | 08:58 PM
Bullshark001's Avatar
Bullshark001
Stage III
Default Dyna Wide Glide Steering Head Bearing
Hi, I am new to the Harley and haven’t ridden in a long time. I have bought a 2017 Dyna Wide Glide with 3500kms on it. I have put 1000kms on it and absolutely love riding it.
I took it to a mechanic to have the fluids all changed and to give the bike a once over and safety check.
He says since it has low Kms it would have been sitting around for a fair while with the steering cocked to the left, and he says the bearing will have a flat spot and should be replaced. I’m just wondering peoples thoughts on this?
He also suggests I replace the engine mounts and I should replace them every year. To do both these will set me back about $2000.
I’m only suspect on these because there are such low kms/mileage on the bike. Feedback appreciated thanks.
Old Aug 14, 2023 | 09:27 PM
spartan03's Avatar
spartan03
I'm a doc and we like to say "get a second opinion"
Old Aug 14, 2023 | 09:33 PM
TwiZted Biker's Avatar
TwiZted Biker
Been working on and riding harleys since the 70's and I have never heard a fraction of the nonsense I have about head bearing as the last 5-10 years.
Unless it's been outside and wet constantly, sitting isn't going to pit a head bearing.
Old Aug 14, 2023 | 10:51 PM
hattitude's Avatar
hattitude
First time I have ever heard of static weight causing a "flat spot" in a bearing.....
He wants to replace the head bearing just based on time and sitting around on the jiffy stand with the wheel cocked...
He says to change out the front & rear engine mounts just based on time. Then replace them once a year as preventative maintenance....
Based on what you've reported, it sure seems to me that he is taking advantage of your lack of Harley knowledge and is trying to make money off you...
Everybody has the right to an opinion, but unless you somehow misunderstood him, I wouldn't allow him to wash my motorcycle....
If I were you, I'd be looking for a new mechanic...
IMHO...You can feel when the head bearings have an issue (either adjustment or wear issues) and you will feel increased vibrations if the engine mounts need replacing and/or you can see the damage to the engine mounts...
Enjoy the bike, and find a new mechanic...!
Old Aug 14, 2023 | 10:56 PM
Harley_ish's Avatar
Harley_ish
Hmm, Bad bearing ("flat spot") after being parked for a long time?
Well, maybe if it was parked in a railroad box car and traveled the rails for mucho miles (or kms)
Old Aug 14, 2023 | 11:40 PM
Ghost_13's Avatar
Ghost_13
Find a better mechanic
Head bearings don't go flat..., motor mounts do deteriorate.., but only when oil spilled on them and then over time (be the front one under the oil filter dead center of the frame) - but your bike ain't got that many miles to have had that many oil changes
Ghost
Old Aug 15, 2023 | 03:53 AM
FX WideGlide's Avatar
FX WideGlide
Default I say no.
Sounds like an old wive's tale to me. I say no, head bearings won't develop a flat from sitting parked. Maybe the mechanic needs to make a boat payment.
Old Aug 15, 2023 | 06:08 AM
jake24lt's Avatar
jake24lt
So by that metric, every car on the road that sits for a while ( with thousands of pounds) has flat spots on the wheel bearings? He has ***** calling himself a mechanic!
Old Aug 15, 2023 | 07:30 AM
Architect's Avatar
Architect
Total BS, go for a ride the bike is fine.
Old Aug 15, 2023 | 10:34 AM
chief08's Avatar
chief08
if i were you i would burn rubber in his face and never go back
