Stalling while riding 02 FXDWG
Back around 2010, I had a similar issue caused by a bad ignition switch. In that case, there would be no power to the bike (i.e., dash & lights would shut down). In this case, I still have power to the bike, so I think it's not the switch. I also have had the stator go out (maybe around 2012), which had a similar symptom, but in that case the battery was going dead, obviously, since it wasn't charging. Not happening here now. Maybe related, or maybe not, sometimes when I start the bike, it does a single crank, pregnant pause, then cranks normal and starts... feels kind of like the motor catches on something, then gets over it.
Any guesses on what I should be looking at here? I plan to test the voltage regulator, stator, coil, check for broken or loose wires... what else?
I've been doing diag on the bike all day today and keep coming up with nothing. Crank sensor & voltage regulator are cheap enough that I'll just go ahead and throw new ones on. It's probably going to be an issue where I just have to ride it until the problem gets bad enough to throw a code or present itself to the point where it can be diaged.
A 2002 probably won't throw a code crank sensor code. The reasons is that from 2001 up, the cam sensor was removed.. It's not needed. The ICM uses crank slowing to determine cam phasing.. If the CKP sensor fails the ICM simply thinks the motor has stalled.
