Positive Wire Location
Old Oct 21, 2023 | 08:36 PM
raymondk's Avatar
raymondk
Default Positive Wire Location
Removed the battery box & unplugged the positive (red) cable , now ​​​​​​I forgot​ where the other end connects to.
stupid me I know, any help is appreciated
2014 FXDB
Old Oct 21, 2023 | 08:43 PM
Hey Man's Avatar
Hey Man
Year and model of the bike would help
Old Oct 21, 2023 | 08:45 PM
raymondk's Avatar
raymondk
sorry it’s. A 2014 FXDB
Old Oct 21, 2023 | 09:21 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Red end to battery + post, other end to that big copper stud on the starter solenoid...
Old Oct 21, 2023 | 09:36 PM
hattitude's Avatar
hattitude
2014 FXDB
The positive battery cable goes to the starter solenoid stud... all my bikes had a rubber cover over that solenoid stud.
Well, at least it does on my '01 FXSTS, '03 FLSTCI, '16 FLHTCU, and my '16 FXDL.....
NOTE: 98hotrodfatboy typed faster than me.... but I included a picture...
Old Oct 22, 2023 | 07:50 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The black cable on the copper stud on the starter is your frame ground the red boot goes on the copper stud on the starter. The red tape just below the red rubber boot identifies it as the positive cable from the battery.
Old Oct 22, 2023 | 08:50 PM
John CC's Avatar
John CC
Better check that. There should be a heavy wire on there that runs to the main fuse, along with the battery cable in your hand.. I think it should be red, at least it is on my '07. Could that be a red wire under black tubing?
And, yes, there should be a boot on that connection. It's hot, high current and unfused.
Old Oct 22, 2023 | 11:01 PM
hattitude's Avatar
hattitude
Are you sure that's not the main harness positive wire...???
It could be #5 in the pic below.
I believe I also see the #43/44 connector to the starter, from that same harness, attached to the starter below the lug.... as well as the neutral switch wires #54, from that same harness section
OP, in any case it definitely needs to be checked to make sure it's not a ground before connecting the battery cable.....
Old Oct 23, 2023 | 06:17 AM
98hotrodfatboy
5/39 is the main power supply to the 40a main fuse and is powered off of the starter lug..
niv
Electrical/Lighting/Alarm
15
Feb 2, 2021 08:35 AM
blackflame
Dec 2, 2013 12:30 PM
cavalier2000
Aug 5, 2012 04:48 PM
bulldawg10
Oct 13, 2011 07:14 AM
SmokerMI
Oct 9, 2008 08:47 AM
