Starter solenoid push button
Old Oct 22, 2023 | 12:07 PM
nghieplk's Avatar
nghieplk
Default Starter solenoid push button
Hi,
I has a very stiff, hard to push starter solenoid button (popular vtwin/midusa button cover). What cause it? How can i make it softer easier to press like replace spring or something?
Thanks!
Old Oct 22, 2023 | 12:31 PM
WP50's Avatar
WP50
First thought would be to take it off.
See if things are corroded up or bone dry.
Clean it and lube it.
WP
Old Oct 22, 2023 | 02:32 PM
John CC's Avatar
John CC
Don't try to make it too easy to push. The last thing you want is for it to make contact accidentally.
Old Oct 22, 2023 | 03:08 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by nghieplk
Hi,
Thanks!
Old Oct 22, 2023 | 03:27 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Just make sure the electrical components and connections in the starter circuit are clean and in good working condition and you won`t need the button.
Old Oct 24, 2023 | 06:14 PM
1981 suprglide's Avatar
1981 suprglide
NEW UNIVERSAL 12 VOLT 3 TERMINAL SOLENOID WITH PUSH BUTTON intermittent 7-1012 | eBay this works nice
Old Oct 24, 2023 | 06:29 PM
John CC's Avatar
John CC
I thought he was talking about one like this.
Old Oct 24, 2023 | 07:31 PM
Max Headflow's Avatar
Max Headflow
One of the main issues why the button would be hard to push is that the jackshaft is binding.. Remember that the button also pushes the pinion gear out into the ring gear on the clutch..
Old Oct 25, 2023 | 12:51 PM
TwiZted Biker
That one just pushes the plunger in so the big washer makes the power contacts, just bypasses the button circuit.
It's either dirty and binding or the OP has white collar fingers, they did take a little push to work right.
Old Oct 25, 2023 | 03:53 PM
Max Headflow
I assumed it was like the one John CC posted a link to.. Isn't that the popular one?
