Tin swap question
Old Feb 7, 2024 | 09:58 PM
parrishbjj's Avatar
parrishbjj
Default Tin swap question
I have a 2012 fxdc with a custom paint job on it and a ton of miles. Looking at a good deal on a 2016 street Bob with only 7500 miles. Only way I'd buy the new one is if I can put my my custom painted fenders and tank on the new bike. Then put the new tins on my old bike and sell it.
Will 2012 tins and tank fit on a 2016 street Bob frame?
Old Feb 8, 2024 | 06:18 AM
eighteight's Avatar
eighteight
FWIW
They share the same p/n for front fender
Not the same #`s for rear fender or fuel tank
Doesn`t mean it will or will not work
Old Feb 8, 2024 | 07:06 AM
ThePaintPirate's Avatar
ThePaintPirate
They should but be sure to read up on if the connectors for the fuel pump are the same. Ran into fuel pump issues with swapping an 09 tank for an 07 on my Softail.
Old Feb 8, 2024 | 11:57 AM
misfitJason's Avatar
misfitJason
The fenders themselves will switchover fine.
The gas tanks are two seperate part numbers because they are different. Streetbobs has dual gas caps. The Superglide has a center fill cap on the regular Superglide. The top plates may be the same if the dashes are the same.
Old Feb 8, 2024 | 12:49 PM
WS6 Formula's Avatar
WS6 Formula
They have the same frame, same part number:
2012
https://shop.suburbanharley.com/oem-...8eb82be8475f/y
2016
https://shop.suburbanharley.com/oem-...b552f9fc8d35/y
Old Feb 8, 2024 | 03:35 PM
parrishbjj's Avatar
parrishbjj
I would use rhe dash from my current bike as long as the plugs are the same.
From what I'm reading it sounds like it should all swap over.
Old Feb 9, 2024 | 11:36 AM
Crazy's Avatar
Crazy
Actually he's got an FXDC, Superglide Custom, which has the dual gas caps. Actually gas cap on one side and gas gauge on the other.
I own both a Street Bob and FXDC. That's good you're going to use the dash from the FXDC. The FXDC and Street Bob tanks are shaped differently from each other, and the dash's probably wouldn't swap without some work. The plugs should be the same because both bikes are canbus.
Be sure to show us some pics.
Old Feb 14, 2024 | 10:53 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Subbed, I want to see the before and after pics.
Indy-Pendent
Jun 15, 2015 02:46 PM
OhioSkully
Mar 22, 2010 11:26 AM
dxrich
Jun 18, 2007 11:24 PM
MikeK02048
May 5, 2007 05:44 PM
fripple
May 21, 2006 07:50 PM
