Inner primary bearing race spining
Old Apr 29, 2024 | 11:08 AM
  #31
WS6 Formula's Avatar
WS6 Formula
Originally Posted by Gilles Grenier
This is a friend’s new part and fitment is for my bike . I’m afraid that the oem or the S&S will do the same .
Drag Specialties Inner Primary Mainshaft Bearing Race - 1120-0305
1120-0305 Wrong one for your bike
Drag Specialties Inner Primary Mainshaft Race Bearing (Check Fitment)
https://www.denniskirk.com/drag-spec...rd/0203034.sku
Tomorrow I’m gonna purchase the oem one 34091-08 and try it
34091-08 The right one for your bike
Originally Posted by Rounders
Is there a site with this as PDF, so I can save it? I have a 2007 made in april 2007. Looking at dates, this doesn't effect me. But I wouldn't mind downloading in a pdf to have.
I only have what I posted, screen shots from Google and Google Image searches. See original thread for more info:
2006 Inner Primary Bearing #3 and Transmission Main Drive Gear Bearing Removal Photos:
https://www.hdforums.com/forum/showt...eferrerid=9012
Old Apr 29, 2024 | 12:22 PM
  #32
Max Headflow's Avatar
Max Headflow
Originally Posted by Jackie Paper
Knowing you know what precision measurements are. Have you ever checked a new OEM shaft and sleeve to determine exactly the amount of press Harley engineers came up with?
There is a limit since when you start say going to 0.001 press, the OD of the inner race is going to grow apx. 0.0005
As many sleeves that I have seen move on here, I personally would not depend on Loctite. I went on the Loctite site for those mentioned above. And I have a Commerical grade 680 called out on a spec but in this case, race was trapped in a case with a snap ring. I was looking and it said it would take approximately 200 ft-lbs to move for a ballpark average of a 1" sleeve. So that may work. Sure would not want to depend on it for a trip bike. The worst case is it's going into a transmission seal I guess.
And obviously, the complete bearing one offered is a slip fit on the shaft and depends onload for the easiest thing to turn.. The bearings..
Don't know exactly but have measured from 0.0005 to 0.0010.. That is what I would figure as a good press fit. The sleeve might grow 0.0005 if the press is 0.001. I see it when doing Timkens as a difference between running the bearings on a test holder and after installed on the crank. The running clearance on the roller bearing is probably between 1 to 2 thou so the expansion of the inner sleeve is allowed for.
If this were a pre stepped mainshaft, I wouldn't bother with the locktite. I'd use a 3205 or 6205 ball bearing.. Since this shaft has a step, it won't run into the mainshaft seal in the main drive gear.
If this one comes loose, it is captured between the clutch hub and the step.
Old May 2, 2024 | 10:40 PM
  #33
Gilles Grenier's Avatar
Gilles Grenier
6th Gear
Hi guys , I’ve installed the Harley race 34091-08 and a new oem inner primary bearing . I have to press it and it was very tight . Just want to thank you all for your time and advices . No more spinning race ! Ride safe !
FXD_noob
Sep 21, 2023 07:28 PM
MURPHCC1
59
Aug 17, 2017 05:14 PM
FroggyFatBoy
47
Jun 7, 2015 05:57 AM
JustLoafin
Aug 4, 2009 11:15 PM
