Front end clunk
Old Jun 13, 2024 | 01:32 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Originally Posted by benscratchin
What model and year is your bike? My 2000 WideGlide had a front-end clunk when I bought it. I found the article attached below and read through it and followed the advised steps. It worked for my bike.
https://www.hdforums.com/forum/frame...front-end.html
Thanks for this. I've checked tank bolts, motor mounts, exhaust, exhaust heat shields and still have it. Hoping this might be the fix.
Old Jun 15, 2024 | 07:35 AM
union53's Avatar
union53
Originally Posted by TexasScooterTrash
Last but not least. Check the front rotor at the rivets.
This is what I'd suggest looking at if everything else is fine. I've pretty much narrowed mine down to the brakes. Went through my bike yesterday to figure this out. Forks were fine off the bike. Triple clamp had no movement or indentations with the wheel off the ground other then going side to side. Tank bolts are tight. With the wheel against a chock and pushing from the bars with no brake applied there is no sound. With the brake applied and pushing from the bars in the same manner there is a clunk. One thing about brakes is everything moves and jiggles a bit when they are not in use such as the rotor and the pads.. My rotors move a bit more then most since they have been replaced with Braketech rotors which do jiggle around a lot. I'm think if the rotor buttons were super tight then the clunk would be less or none at all. That is not how these rotors are designed but the stock ones are a lot tighter. To the point I don't even know if I would call them floating rotors.
Only other source I can think of in my case is the fender. I'll confirm that in a bit when I go for a quick ride without it.
Old Jun 15, 2024 | 04:49 PM
oldmanriver1933's Avatar
oldmanriver1933
Stage II
check front motor mount bracket, the two bolts that go to engine under oil filter. I had an issue there that made a similar noise. good luck
Old Jun 16, 2024 | 08:04 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Bluesrider.df
I had a klunk on my Dyna Low Rider which turned out to be low fork oil.
https://youtu.be/9a486UhQMBY?si=n2eWLSGj8qLK2WhB
Man that's a lot of dive.. I didn't think one could get 5"of travel..
OP, the fall away method for the neck bearing ( in my opinion) are a little loose for my liking an can occasionally cause a klunk or knock.. I like to set bearing preload to where it will take on finger with gentle pressure to move the bars when on the jack stand.. Been doing it this way for ever without issues..
Son of PMS
EVO
24
Jan 24, 2024 10:46 AM
Baja38ss
Apr 14, 2014 08:30 AM
vladt
May 27, 2010 05:51 PM
Beagle1
Apr 23, 2007 12:13 AM
mtonyl
Apr 2, 2007 07:52 PM
