2006 Wide Glide
Old Sep 1, 2007 | 02:00 PM
dunn123167's Avatar
dunn123167
Stage II
Default 2006 Wide Glide
I was riding last night and the battery light and the check engine light both came on. I come up with a PO562 code. It also says pn34256-06. I see this is a low battery voltage efi code. Has any body had this before? Also The same time i started noticing a noise, sounds almost like on the left side. When reving it sometimes makes it on the down side, when rpms are coming down. I started it again and I can't get the noise now. Last night it sqeeled while riding. It has been 7000 miles since an real service work has been done, which was the stage 2 kit. Please help. The dealer is closed for the three day weekend.
Thanks
Old Sep 1, 2007 | 06:56 PM
dunn123167's Avatar
dunn123167
Stage II
Default RE: 2006 Wide Glide Check engine lights
Has anyone else had simular check engine light issues?
Old Aug 27, 2008 | 06:00 AM
Dingobob's Avatar
Dingobob
found this while searching.
I am having exactly the same problem now right down to the noise. did you manage to find problem. has anyone else had this problem?
mines an 06 street bob
Old Aug 27, 2008 | 07:22 AM
Mascman's Avatar
Mascman
Check out the thread about the self - destructing stators...may be a warning sign.
8upguitarman
Dec 21, 2012 10:26 AM
Kbore
Aug 26, 2009 02:56 PM
dmello
Nov 16, 2008 09:36 PM
Suburban28
Exhaust System Topics
Jun 29, 2006 03:30 PM
Wide Glide 05
Aug 28, 2005 10:22 PM
