Need help with jetting
Old Aug 21, 2024 | 07:04 PM
GbJax's Avatar
GbJax
Stage I
Default Need help with jetting
So i recently bought a 95 dyna superglide and it runs but needs jetted bad. It came with some V&H straight shots and a arlen stage 1 air cleaner. I plan on getting a 2 in 1 down the road to help but cant afford it at the moment. So im looking at jets. It coughs quite a bit and runs pretty lean.
Old Aug 21, 2024 | 08:18 PM
brakeless's Avatar
brakeless
You could probably start out with 185/45.
Old Aug 21, 2024 | 08:23 PM
Tommy C's Avatar
Tommy C
A N65 needle makes quite a bit of difference for throttle positions between 1/4 & 3/4 throttle. Might be a good idea for the OP to pick one up.
Old Aug 21, 2024 | 08:32 PM
brakeless's Avatar
brakeless
Several websites online to help set up your carb.
This is one:
http://www.nightrider.com/biketech/hd_cv_mods.htm
Old Aug 22, 2024 | 06:24 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Check your accelerator pump...
Old Aug 22, 2024 | 09:13 AM
brakeless's Avatar
brakeless
Also on that old of a bike the intake gaskets could be bad. An intake leak makes it cough and run lean.
Old Aug 22, 2024 | 06:41 PM
NORTY FLATZ's Avatar
NORTY FLATZ
I'd wait until if/when the OP returns.
Old Aug 22, 2024 | 07:20 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Checkout nightrider.com/biketech,, click on performance guide, there is a drop down menu on the right, scroll down to modifying carb and tuning the carb. There is a lot of information there.
Old Aug 23, 2024 | 04:31 AM
Yankee Dog's Avatar
Yankee Dog
Don't drill the slide like Nightrider suggests. If you did then replace the slide and keep the drill bits away from it. Set the carb up as original with the exception of changing out the needle and fine tune the jets to fit your mods. YD
Old Aug 23, 2024 | 08:07 AM
Tommy C's Avatar
Tommy C
...and don't cut the vacuum plunger spring, either.
